99 Camry 4cyl misses when accelerating. No codes
99 Camry, 4 cyl, 5 sp. 165,000. Fuel filter, air filter, plugs, wires all done in the last 20,000 miles. The car bogs down when accelerating through the gears. It misses, hesitates and even back fires. Importantly, it does this most severely when the RPMs on the low side and I put my foot in it. For example, if I shift into 3rd and the engine goes to 1700 RPM and I try to accelerate quickly from there, I get major hesitation. If I keep the revs high while doing the same thing, the hesitation is there but not nearly has pronounced. I went to AutoZone this AM and there were no codes registered in the computer. I put some fuel injector cleaner in the tank. Maybe some of the injectors are dirty? More likely I'm thinking it's a fuel pressure regulator or pump. I need to invest in a fuel pressure kit to test to be sure. Any other ideas out there?
