Check to make sure you can switch settings. If you don't see it or feel it switch settings, either your motor is bad or a linkage is loose. I had the same problem and got it fixed right up. When I set it to defog, I have to move it off that setting quick (on rotary controls) for it to disengage. You might have the opposite problem, try setting it to leg vents only, and quickly set it over to defog.
If it is engaging, is there a loud pop?
1993 Toyota Camry LE 4 Cylinder
Running 100%
