Car cannot go faster than 85mph. *FIXED*
Hello all,
Thanks to the wonderful help this forum has provided me, I was able to replace my timing,ac,power steeriing belt, camshaft, crankshaft, oil seals, tensioner pulleys, and idler pulley.
But I have a new problem. The car won't accelerate past 85 miles per hour even when the gas pedal is floored. What would cause this issue?
Update:
I fixed the problem by readjusting the timing. I set the crankshaft back to the 5 notch, aligned the camshaft to the V-notch, put the belt on and rotated the crankshaft 720 degrees. Apparently my timing was off so it affected my engine performance drastically.
Thanks all that helped!
08' E90 335i
08' E92 M3
96' Camry
