Engine rocking - Broken Flex Pipe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2009, 06:15 PM   #1 (permalink)
View LUVLEXUS101's Photo Gallery
So the title pretty much says it all. A couple of years ago I had the entire header replaced now the flex pipe is leaking. Took it to the muffler shop spent 140 replacing one of the flex pipes. The guy there said the bad engine mount is causing the pipes to break/leak. So are there two mounts on the bottom? I already replaced the dogbone one and another one. How much should it cost me in labor to replace the bottom one(s)?
LUVLEXUS101 is offline   Reply With Quote
Old 03-15-2009, 06:46 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
There are 4 mounts. Dog bone, front emgine mount, rear engine mount, and the transmission mount. IMO the best thing to do, really, is replace all the mounts together. Yes, it'll be more expensive, but that way you can be sure all the mounts are good.
I have no idea what the labor will cost, because that depends on where you go to get that done.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
