Master Key for 2001 Camry! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2009, 06:55 PM   #1 (permalink)
View AzN1337c0d3r's Photo Gallery
Hi, today I went down to the body shop to pick up my Camry after it had an accident. While they were fixing the body they had lost my key and had to replace it. They bought a genuine Toyota "master key" and then programmed it and made it all work fine and dandy, but did not program the remote fob.
So I asked them to print out the instructions on the remote fob so I could program it right there. That seemed to work properly, but now none of my keys will start the car now!
All I hear is rapid clicking when I try to start the car using all 3 of my master keys and all the valet keys as well.
So my question is, is it possible that I have deleted every single master key and valet key from the ECM!? If not, what else could cause an engine to not turn over?
1998 Toyota Camry LE V6 - 98k miles - Parent's daily driver (which I have been driving as well until recently)
2001 Toyota Camry XLE V6 - 75k miles - Will be my daily driver when I head back to college.
AzN1337c0d3r is offline   Reply With Quote
Old 03-16-2009, 07:54 PM   #2 (permalink)
View toyomoho's Photo Gallery
The engine does not turn over or turns over but does not start?
Old 03-16-2009, 08:20 PM   #3 (permalink)
All i hear is clicking noise
Old 03-16-2009, 11:26 PM   #4 (permalink)
Gameroom cash: $167450
View nfsuw's Photo Gallery
this is just a thought, maybe your starter motor died... about a year back, i had that problem, the car wouldnt start, kept clicking when i tried to start. replaced the starter motor and it started.
also, i didnt know gen 4 camrys came with chipped keys... at least none of my keys are chipped, but then again, my gen4 has an aftermarket remote installed...
nfsuw is online now   Reply With Quote
Old 03-16-2009, 11:51 PM   #5 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
rapid clicking means dead battery. happens all the time at body shops because they leave a door off without disconnecting the batt, or weld on the car with the batt still connected, frying it. make them give you a new battery.
and you're right - afaik, gen4's don't have transponder keys.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 03-17-2009, 07:50 AM   #6 (permalink)
View skuttduck's Photo Gallery
My owners manual for my 2000 camry talked about keys with chips in them. Mine doesn't have this, but it was probably for the security system.
skuttduck is offline   Reply With Quote
Old 03-17-2009, 03:59 PM   #7 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
The gen 4 did indeed have chipped keys on certain models I believe. Probably V6 and XLE models, at least in the US. The OP will know if his/her keys are chipped if the valet key is a rubberized gray color. If not, the valet key is a regular metal key.
OP - have your battery checked and if it's good, it might be the engine immobilizer kicking in and disabling the starter..
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
