Yes, I have replaced my door handle and it's somewhat of a tough task considering if you don't drop your bolts inside your door. The first time can be tough but later on it'll get easier. First, you would have to remove your trim panel then remove some of the plastic water shield thing. then there's two bolts located on the left side of the door handle that are kinda hard to get to that you'll need to remove. Then a bolt on the right that's in plain sight that you can remove. After that, you have to flip up the clip that's connected to the linkage rod then try pushing the handle up and out. Hope this helps, good luck!
