experts: need EGR help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2009, 04:14 PM   #1 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
the codes the car is throwing are:
P1411 manufacturer control auxilary emissions controls(after replacing EGR valve)
P0402 excessive EGR flow
hey guys, tryin to sell my gen4 V6 but before i do i was trying to get the car runnin perfect. im expreiancing rough idle after the car warms up but the engine doesnt stall. it also does it in gear when under about 2500 RPMs, still no stall. it also becomes a little tougher to start.
after asking a few people the thought was that it was the EGR valve was stuck open thus letting too much spent gas in at low RPMs. went to the junkyard and snagged a much newer looking EGR valve. just poped it on and no luck. same symptoms and the new p1411 code.
what do yall think? as i understand it the EGR system is fairly simple and there could only be a few things causing this problem. any help would be great.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-17-2009, 07:54 PM   #2 (permalink)
View finfinder's Photo Gallery
Does the v6 have an EGR modulator and VSV as well ? Can you get them from the same car you got the valve from ?
finfinder is offline   Reply With Quote
Old 03-17-2009, 09:05 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
yes it does have thoes but im not sure if i can source all the parts from the same year. im not as versed on teh gen4 as the 3 but as far as i know there were no changes to the egr system from 97 to at least 00. so thoes parts should. im assuming that your gettin at the fact that teh vacume system may be causing the valve to stay open? i didnt think of that.
R.I.P.
Car Domain:
Old 03-17-2009, 09:13 PM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Yeah, I would check out the VSV.
A new one from Toyota is about $80.
Can't hurt to take it off and poke around with an ohmmeter.
Chris Crash is offline   Reply With Quote
Old 03-17-2009, 09:37 PM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
check your vsv like they said, and be sure that the modulator isnt clogged...because the modulator, if im sure closes off the egr valve, and it seems like to not closing it. or either the vsv is apply alot of vacuum holding it open...just a thought of how i see it working
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 03-18-2009, 08:57 AM   #6 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
i also agree - the vsv could be stuck open, thus keeping the egr open. just pull the vac line off the egr valve and see if it runs better (plug the line so you won't have a vac leak).
check the rest of your hoses to make sure you don't have a vac leak anywhere - this would also give you poor idle and rough running below 3k rpm. prime suspect would be charcoal canister, but then typically when you have a vac leak there, you also get at least one of the dreaded EVAP trouble codes (p044x).
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 03-18-2009, 03:11 PM   #7 (permalink)
Correct !
The best thing about the EGR system is that it does not contain many parts and the valve itself is the most expensive. The modulator is relatively inexpensive and the VSV is only about $80 as Chris said.
Old 03-18-2009, 05:23 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
great thanks guys. ill check out that vsv.
R.I.P.
Car Domain:
