3VZ owners - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2009, 04:59 PM   #1 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
3VZ owners...and BHG
i'm just wondering how many other 3VZ-FE owners out there are having overheating/boilover problems.
i've had this same problem with the previous motor. i'd be able to drive for 30 mins max before it started to overheat/boilover. i replaced almost everything thats part of the cooling system. then from there it just went downhill. it went to only 20 mins of driving, then 15 mins, then motor oil became milky.
so then in may '08, i just had enough of that and bought a used 3VZ from japan. also, spent another $1200 on parts like a new radiator, water pump, thermostat, spark plugs, wires, etc.
Then today, after driving for 20 mins, i park in at home depot to get some stuff. when i get out of my car, i can smell coolant. sure enough, some guy walks over and says there is coolant all over the place. i pop the hood and the coolant from the resevoir is boiling.
TheKevin is offline   Reply With Quote
Old 03-17-2009, 05:15 PM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
I had that same problem with mine.
I replaced the water pump, radiator, thermostat and anything remotely connected to the cooling system, now it runs Ice cold
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-17-2009, 06:13 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
check the headgasket....yet again...
HaHa
Old 03-17-2009, 06:18 PM   #4 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
hater!!
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 03-17-2009, 06:59 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I had the same issue where it would boil over. I think mine was related to not being properly bled to get all the air out. Happened a few times and now it hasnt done it in a long while. Didnt replace anything. Oil has never got milky (thank God). I was scared that I had a blown HG, but I didnt.
Have you ever tried a coolant flush?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 03-17-2009, 07:03 PM   #6 (permalink)
TN Pussy Man
Originally Posted by midnightmach View Post
hater!!
lol
no...just being realistic unfortunately.
but yes, spend an hour or so bleeding the system to be sure and then see if it still happens. if it still does and you've changed every component related to cooling...then it's not looking good
HaHa
Old 03-17-2009, 11:51 PM   #7 (permalink)
TheKevin's Avatar
other than the head gasket, what else needs to be replaced? im going to hit up my mechanic in a couple days.
Old 03-18-2009, 05:17 AM   #8 (permalink)
Knailgun's Avatar
water pump, thermostat, flush the radiator
Old 03-18-2009, 11:55 AM   #9 (permalink)
View davemac2's Photo Gallery
Boilovers are usually the head gasket, especially if you have just done highway or sustained high speed driving for 30+ minutes which stresses the block-head interface the most. Try doing a chemical block test for confirmation. The kits are only $30 or so. It can also be a bad coolant cap or poor coolant circulation due to a clogged rad or trapped air, but this is not typical unless the cooling system has been badly neglected or work on it was recently performed. Corroded water pumps will usually show as temperature creep. I think these 3VZ-FE V6's are prone to head gasket failure on cylinder #6 (right most cylinder at the front on driver's side.). It's almost always that one. I've had it happen twice on these engines, almost the same situation as you with a japan imported replacement engine failing yet again in exactly the same way and cylinder. My second one lasted for 3-4 years though (60K). I will have to get around to posting my pics of my 3VZ-FE head gasket job on here soon. It takes a good 12-16 hrs of labor to do these gaskets. If you take the shortcut of only doing the front head (reasonable for the typical failure mode on this engine), you can probably knock 5hrs off the job. The first engine that failed for me was unrepairable because the gasket failure had caused bad corrosion pitting on the block surface and a HG repair would not likely last long. This is always a risk, especially if you have not caught the HG failure early enough.
dave mc
davemac2 is offline   Reply With Quote
Old 03-18-2009, 02:11 PM   #10 (permalink)
TheKevin's Avatar
^exactly. the previous motor was just FUBAR. i kept driving it until it was too late.
i just got a $800 quote from my mechanic to do a HG job. parts and labor.
Old 03-18-2009, 05:48 PM   #11 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
dang this is happening to everyone....my car is still in the shop gettin the motor replaced....
after reading dave's post im afraid about the replaced engine now...just hope mine will last as long as his replace motor....
and dave, yea please do a 3vzfe hg replacement diy or post some pics....because as you all have know, this is happening to everyone
93XLEcamry is offline   Reply With Quote
Old 03-18-2009, 07:14 PM   #12 (permalink)
that's a very good price actually. I've been quoted $1500 about 3-4 months back. Maybe he is planning only to do the front head.
dave mc
Old 03-18-2009, 07:31 PM   #13 (permalink)
TheKevin's Avatar
93XLEcamry, how long has it been in the shop? it should take 2-3 days to install. be prepared for a HG job later.
ok, if i replace the HG do i need to resurface the heads? also, how likely is a BHG going to happen again?
Old 03-18-2009, 07:37 PM   #14 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
If you do it again... it could last you another 150,000+miles, or it could last 50,000, there really is no true way of telling. Sorry to hear that man, I was having the same issues before I totalled mine... kinda took care of the issue.
BlueFusion6851 is offline   Reply With Quote
Old 03-18-2009, 07:43 PM   #15 (permalink)
TheKevin's Avatar
dave mc
the price is for both heads and all the other little necessities, including resurfacing the heads. he does great work and i trust him. he's worked on my other cars and havent had any problems with those.
as of right now, i'm just a little fed up with this camry. i've put a lot of $ into it, mainly repairs. so right now i'm thinking of parting out and just taking a huge loss and sellin it or rolling it off a cliff.
