I've used that sealer, and can guarantee it won't 'stick' anything together. It just fills voids so the exhaust gasses won't escape. It does adhere to the parts you smear it on, but you can easily disassemble and wire brush/scrape it off and use them again. However, all this stuff is is a gasket enhancer or substitute. I've used it more to patch a leaky muffler in a pinch, to get MVI done. I can't see where it would have anything to do with your bolts loosening up problem though. Put lockwashers in and torque them down hard. Unless you do your own work, a muffler shop will just torch them off anyway and replace them with new ones (and charge like h*ll for them too).
