10mm Spark Plug Wires! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2009, 02:35 AM   #1 (permalink)
Toy_Dreamer's Avatar
View Toy_Dreamer's Photo Gallery
4th Generation 10mm Spark Plug Wires!
Does anybody know where I could get 10mm spark plug wires for my Gen4? (If they make them)
AND; What kind should I get (as well as the spark plugs)..
Thanks TN'ers
1998 Camry XLE | Black | Custom Halo Lights | Fogs | Infinity Kappa front speakers | Infinity Reference Sub | SRI Secret Weapon R...
Toy_Dreamer is offline   Reply With Quote
Old 03-18-2009, 03:22 AM   #2 (permalink)
1MZFE Marauder
View MrKrispy1183's Photo Gallery
I don't know about 10mm, but Magnecor makes up to 8.5mm
Magnecor
Wires 8mm 7mm 8.5mm
3.0 V6 60212 67212 65212
2.2 I4 40298 47298 45298
-Brian
MCV20 Solara: Injen/UPFD/GReddy/TRD/Megan/WORK equipped
MrKrispy1183 is offline   Reply With Quote
Old 03-18-2009, 09:04 PM   #3 (permalink)
View angel_rolla's Photo Gallery
how bout the nology one?
angel_rolla is offline   Reply With Quote
Old 03-18-2009, 09:07 PM   #4 (permalink)
what's nology?
Old 03-18-2009, 11:02 PM   #5 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
This info is straight from the Magnecor website under FAQ about Igntion Wires.
http://www.magnecor.com/magnecor1/main.htm
9. Do I need an 8.5mm or a 10mm size wire if my original wires are just 7mm (or smaller) ?
If you don't intend to upgrade your vehicle's original ignition with a high-output ignition, you may not need larger size wires. Magnecor KV85 and R-100 Race Wires have been designed primarily for race engines that will be run with high-output ignition systems, and contain high-capacity 2.5mm conductors that require extra insulation when used with extreme-output ignition systems. Magnecor Race Wires will also be exposed to heat an unmodified production vehicle will never experience. However, the major advantage Magnecor Race Wires have over conventional 5mm, 7mm and 8mm wires is that neither the high-capacity conductor nor the insulating jacket will wear out during the life of the engine.
11. What gain, if any, will I get using 10mm size wires compared to 8.5mm size wires ?
Our R-100 (10mm) cable has a thicker insulating jacket, designed for extreme heat situations or where extra insulation is needed for extreme-output ignition systems and where it's not easy to space the wires from one another and/or the engine. Our KV85 (8.5mm) and R-100 (10mm) cables both use the same conductors and provide the same spark energy output, and, as most street and modified production engines don't really need a cable size larger than 8.5mm, using our 10mm size cable is usually overkill (or for appearance). Please understand our 10mm cables, due to their large diameter and bulk, will take more room, and a little longer to fit and loom correctly.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 03-18-2009, 11:28 PM   #6 (permalink)
Originally Posted by Toy_Dreamer View Post
what's nology?
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
