92 Camry (190k) with a lot of work ahead. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2009, 02:50 AM   #1 (permalink)
03 Camry & 06 Sienna
View sljorge's Photo Gallery
USA 92 Camry (190k) with a lot of work ahead.
Hi all, newbie here with major work ahead:
  1. Radiator blew all over the inside of engine compartment (cracked along top near rad cap). New rad came UPS today and got new hoses from Checker.
  2. Need to drop tranny pan and flush a/t fluid.
  3. Have huge oil leak from classic back right corner, so I'm gonna change out oil pan gasket, oil pump gasket and o-ring, timing belt, water pump, and all other seals that come in the timing belt kit.
QUESTION: What should I do first, in what order and should I do them all at once or piece by piece to make sure I don't screw up one thing and then another?
sljorge is offline   Reply With Quote
Old 03-21-2009, 03:56 PM   #2 (permalink)
View Manny1337's Photo Gallery
first off get the new radiator all set then id say tackel the timing belt belt kit. good luck with that my man haha
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 03-21-2009, 04:03 PM   #3 (permalink)
View toyomoho's Photo Gallery
Back right corner?
Fix the radiator. Remove the passenger tire, start engine and watch for oil leaks on the lower portions of the timing belt cover. If the oil pump seal oil will start dripping down.
Trans pan and radiator are easy fixes. Timing belt, etc is much more time consuming.
