Eibach springs make a noise? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2009, 07:33 PM   #1 (permalink)
old red
old red's Avatar
View old red's Photo Gallery
2000 v6 with eibach springs... at first everything seemed to be juuust fine, but now i get this "tig tig" sound everytime i drive over anything from a little rock to a bump.
i checked the car, everything seems to be fine, everything's bolt tight and all those rubbery bits that go under the car seem to be intact
could it be the springs them selves?
Think deep, act simple.
old red is offline   Reply With Quote
Old 03-22-2009, 09:58 PM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i found worm sway bar endlink make noise, bad strut mount make noise, i am not sure about spring insulator.
bronzemaxell is offline   Reply With Quote
Old 03-22-2009, 10:53 PM   #3 (permalink)
ero
View ero's Photo Gallery
I'm new to toyotas, but going from general experience, worn out or simply aged rubber (bushings, mounts) makes those kinda of creaking noises, especially when it's freezing out (was it when you started hearing the noise?) Did it get better when the engine warmed up?
ero is offline   Reply With Quote
Old 03-23-2009, 04:49 AM   #4 (permalink)
old red
old red's Avatar
i took the car to a mechanic, all those rubbery things were good, also, it's never cold here so "freezing...etc" aint the problem!
i'll check those so called "insulators"
