94 Camry LE ABS codes 38 & 39 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2009, 12:36 PM   #1 (permalink)
Who nolonger has a van
View vanmankline's Photo Gallery
3rd Generation 94 Camry LE ABS codes 38 & 39
The ABS light has come on/off intermittently in my parent's Camry for over a year. We never had issues until the other day when it engaged while gradually braking at low speeds on dry pavement. I decided to check the codes and found that there are/were open circuits in both rear speed sensor circuits (38 = Right & 39 = Left).
Now I'm stuck. I'm not the brake guy in the family (my bro is, but he is out of state). What does this mean? Is an electrical or hydrolic circuit open? Any suggestions where to go from here? What may be wrong/causing this?
Thanks you for your time!
vanmankline is offline   Reply With Quote
Old 03-27-2009, 07:37 PM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
Sounds like both rear speed sensors are not sending signal full-time. You probably got lucky and just need to pull the sensors and clean them of any ferrous metals that are clinging to the sensor pick-up. While you have them out make sure that the wire connections are not corroded. Of course this may not be the case since your ABS engaged under light braking on dry pavement. Could have been a fluke. Maybe not.
frenum49 is offline   Reply With Quote
Old 03-27-2009, 09:24 PM   #3 (permalink)
Thank you for the input. I found some tests to run for wheel speed sensor specific codes. I'm going to perform these tonight when fewer people are on the road & report my findings back here. If they are inconclusive, I'll be able to take stuff apart tomorrow morning when I have more light.
*EDIT*
Add code 34 (Left rear speed sensor signal malfunction) to the list... Wheels will be coming off tomorrow. Don't really want to remove the back seat though...
Old 03-28-2009, 08:09 AM   #4 (permalink)
O-Dark-30
frenum49's Avatar
hmm
Not sure which diagnostic tool you are using to pull codes. Does your have a data display as well as a code puller? Meaning if you have it plugged in and take the car up the road there might be data for the speed of each wheel like my Solus has. Or is it just a palm reader?
Old 03-28-2009, 07:10 PM   #5 (permalink)
Will http://www.babcox.com/editorial/ic/ic30121.htm work on the Camry too? If not that procedure, is there something like it?
Old 03-29-2009, 01:03 AM   #6 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
I have the same problem with my ABS... ABS came on intermittently and the anti-lock engaged under light braking on dry pavement. It has been going on for a while now, but I keep forgetting about it because it happens a few times a week.
Please keep me updated on your problem
Goal for 2011 -- Make the Camry my fastest car
Tony the Tiger is offline   Reply With Quote
