94 2.2l Exhaust Flex Pipe Dimensions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2009, 01:05 PM   #1 (permalink)
otm
View otm's Photo Gallery
Can someone give me the dimensions of the flex pipe section (diameter of the pipe especially) so I can figure out what size replacement section I need to buy. I'll weld it in myself. Thanks.
otm is offline   Reply With Quote
Old 03-27-2009, 03:30 PM   #2 (permalink)
Who nolonger has a van
View vanmankline's Photo Gallery
The exterior diameter of the solid pipe leading to the flex pipe is about 2 inches (maybe slightly less). The actual braided steel part is about a foot long. Does this help at all? Unfortunately I can't give much more exact measurements an the moment.
vanmankline is offline   Reply With Quote
Old 03-27-2009, 03:49 PM   #3 (permalink)
Love Machine
plbill's Avatar
View plbill's Photo Gallery
Yes, I replace it this weekend and the flex have an diameter of 2 inches. Your exhaust pipes should fit perfectly inside de tips. If you can, buy a flex pipe with double reinforcement, they got braided steel inside and outside the pipe and it's more resistant. For the lenght, you will probably have to buy a flex pipe longer than the original because you have to cut the exhaust pipes after the tips of the flex pipe.
Camry 1992 2.2 LE
plbill is offline   Reply With Quote
