P0420 and P0302 and Timing Belt Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2009, 04:05 PM   #1 (permalink)
View camryguvnor's Photo Gallery
Unhappy P0420 and P0302 and Timing Belt Problems
Hi,
I recently got a P0420 code from my 97 Camry LE (has about 130k on the clock). I had replaced the cat about 2 years ago, and since then I have put less then 1000 miles on it. My car is a CA emissions one but I'm driving it in NJ so I figured I wouldn't need the extra expense of the CA cat and it needed to pass emissions so I relaced the cat with a non-CA one...
I think the timing belt is on its last legs as for about 6 months now I can hear it slapping around, but I figured as the engine is non-interference, then when it breaks it shouldnt do too much damage.
I took the car out yesterday for the first time since the P0420 (cat efficiency) code triggered, and on the way back from the store, the Engine light began flashing. I had my OBD in the car & hooked it up and it had given me 2 misfire readings & was running rough. By the time I made it home (5 miles away), the car was shuddering at traffic lights on the point of stalling. It also lost a lot of power when driving.
Could a 2-year old cat be the cause of the problem or is it likely to be the timing belt and/or plugs wires?
Any help would be greatly appreciated!
Thanks!!!
camryguvnor is offline   Reply With Quote
Old 03-27-2009, 06:07 PM   #2 (permalink)
View Manny1337's Photo Gallery
i dont believe the cat would cause anything like this, i could be wrong though. id check the timing belt take the cover off and see how the belt looks and same with plugs check them.
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 03-27-2009, 07:03 PM   #3 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
If your timing belt has been slapping around and now you car runs like sh**, it is a good bet that you jumped a tooth and are now out of time.
frenum49 is offline   Reply With Quote
