P0446 - replaced vsv, now what? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2009, 08:35 AM   #1 (permalink)
View psyclemania's Photo Gallery
I had the P0446 on my '99 V6 Camry, figured it was most likely the VSV, so I ordered a OEM one from an on-line dealer and replaced that, cleared the code. CEL was off for a bit of around town driving, but after 10 miles or so on the highway, it has come back on. So what now?
Here is what I noticed:
1. The replacement VSV had the 'key' on the electrical connector in a different place, it was 'right' instead of 'left' (depending on which way you look at it) but everything else looked the same, so I ground off the key and it plugged right in.
2. When I disconnected the two rubber hoses that are close together on the back side, I could distinctly smell gasoline. Does that mean my charcoal canister is saturated? Or is this normal?
3. I looked at all the vacuum lines and they all look fine, I do not believe I have a cracked or deteriorating hose. The fuel cap is tight.
Any suggestions on what to do next??
Sinister black 1999 Camry LE - 3.0L V6 5sp
35% tint / Grey leather / 15's ASA 5 dbl spoke / Sony/Infinity
psyclemania is offline   Reply With Quote
Old 03-31-2009, 12:54 PM   #2 (permalink)
View finfinder's Photo Gallery
use the search function.
finfinder is offline   Reply With Quote
Old 03-31-2009, 03:22 PM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
If the connector dosent fit, then its the wrong part. It took a while for the light to come back on because the ECM needs to see certain conditions before it runs the Evap system test. The fuel smell is normal when you have the hoses disconnected. The light could be on because you have the wrong valve installed, or it could be something different in the evap system. You need to have it diagnosed properly before throwing parts at it.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-31-2009, 04:18 PM   #4 (permalink)
View Hooker Hunting's Photo Gallery
there is more than one vsv which one did you "diag"
Hooker Hunting is offline   Reply With Quote
