Differnce 1MZFE and 3VZFE engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2004, 02:31 AM   #1 (permalink)
View jtroost's Photo Gallery
I own a camry V6 3.0 (station)wagon
The engine is a 1993 european 3.0 24V with 186Hp.
But is this the 1MZFE ord the 3VZFE engine?
I ask this because i need to replace the cv-joint. On driveshaft-axle.com i want ot order a cv-joint, but the partslist doesn't make a difference between the two engines.
Please help a dutch, proud, owner of a camry.
Jacco
jtroost is offline   Reply With Quote
Old 01-23-2004, 03:23 AM   #2 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
well, i'm not sure if it's the same in Europe, but here in the us, the V6 92-93 camry used the 3vz-fe,and V6 94 and after were 1mz-Fe...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 01-23-2004, 06:40 AM   #3 (permalink)
importfest's Avatar
View importfest's Photo Gallery
I'll second ratko on that one
call up your Toyota Dealership and give them the cars Vin number located at the bottom Driver side window, jussst to be sure
oh Ratko man you pic looks like u wanna kick someones ass
like a dont talk to me look !! haha i love it
back now, perfecting the new
importfest is offline   Reply With Quote
Old 01-23-2004, 06:49 AM   #4 (permalink)
View Nico's Photo Gallery
Re: Differnce 1MZFE and 3VZFE engine
Jacco
Yep it is the same in Europe. In fact there are just a few, minor differences between Camry's sold in Europe and in the US. The main only differences I have known of are different O2 sensor, different fuse/relay boxes locations. Otherwise it is nearly the same
Nico
Nico is offline   Reply With Quote
Old 01-23-2004, 10:02 AM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
wasnt the 3vz like 175-180 hp and the 1mz like 190-195?
dude, wherever you are getting the cv joint from should go by make and model... NOT by engine. you need it for the camry 3.0 v6, not for the 3vz-fe engine... see what im saying... if you cant get it like that, i would say find someone else who has a better system so you get the right part.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 01-23-2004, 10:21 AM   #6 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Simple..open your hood...look at the undeside of the hood (if not repainted...or repaired) and you should see some japanese writing with your engine code...work from there...
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 01-23-2004, 10:44 AM   #7 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Snap a pic of the engine bay and we'll identify it for you in 2 seconds.
importfest: its just my rough exterior... im actually very friendly
ratko.org
Ratko is offline   Reply With Quote
Old 01-23-2004, 11:37 AM   #8 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
3VZ - 185
1MZ - 188 Gen 3.5, 194 Gen 4, 192 Gen 4.5 ULEV/Gen 5, 210 Avalon and Solara
CV joints are supposed to be based on engines, but only between 4 Cyl and V6. It shouldn't be different between the two V6 since they used the same transmission. (At least that's what Kragen's inventory PC showed me when I looked for CV Joints and Boots)
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 01-23-2004, 11:58 AM   #9 (permalink)
Image of the engine
Just took the picture of the engine.
Under the hood the engine is called 3VZFE.
Thanks for the replies.
Jacco
Old 01-23-2004, 12:38 PM   #10 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
Yup, it's a 3VZ
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 01-23-2004, 03:23 PM   #11 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
So what is the difference anyways? How is the 1mz better than the 3vz....or vice versa. Does the 1mz have vvt or something?
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
Old 01-23-2004, 05:57 PM   #12 (permalink)
Resident slacker
kgasso's Avatar
View kgasso's Photo Gallery
Only a few newer 1MZ's have VVT-i
The biggest diff, if I remember correctly, is that the 3VZ is iron and the 1MZ is aluminum.
kgasso is offline   Reply With Quote
Old 01-23-2004, 07:40 PM   #13 (permalink)
Wazzaaap!
is it possible to put a vvti on a 3vzfe motor?
Old 01-23-2004, 09:41 PM   #14 (permalink)
View Kensuke's Photo Gallery
No.
Occasionally Toyota heads are swapable within engine families, but not outside of families.
Get a 1MZ-FE if it means that much to you.
- John
Kensuke is offline   Reply With Quote
Old 01-24-2004, 05:26 AM   #15 (permalink)
Are there some small upgrades?
Thanks for the reply about the engine.
Are there small upgrades to the engine?
The engine is a liitle bit slow until it reaches 4000rpm. At 4000 rpm there's much more power (seems to be).
It will be perfect if there's a change to the engine with more power (Nm) in the regio 2000-4000 rpm.
Jacco
