a little help with gas filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2009, 08:05 AM   #1 (permalink)
View bud659's Photo Gallery
3rd Generation a little help with gas filter
this is a first time thing for me trying to change the gas filter on a 1998 Toyota Camry 5f-SE 2.2l CAL emissions. i just dont want to get raped at the dealer.
I have located the engine gas filter behind the airfilter but am looking for some steps on how to replace?? What exactly has to be removed to get to the top and bottom nut?
here is a general photo of all the stuff in the way
bud659 is offline   Reply With Quote
Old 04-08-2009, 12:00 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
the top of the air filter box has to be removed, along with the tube to the throttlebody and the plastic container dangling underneath. the two electric connections should be disconnected along with those two rubber vacuum lines as well so those parts can be removed. you probably will have to also raise the vehicle, remove the wheel and inner plastic liner to gain better access to the bottom of the filter.
i would highly suggest soaking the connections of the filter with something like Pb blaster and use flare nut wrenches on the lines to disconnect them. use two wrenches on the bottom connection! one to hold the filter, and the other to loosen the bolt. dont want to kink the fuel line.
Old 05-28-2009, 12:51 AM   #3 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
This is where the damn fuel filter is??? Even in a 3rd generation Camry?
1992 Camry I-4 with 145K miles
Deadly Sushi is offline   Reply With Quote
Old 05-28-2009, 12:12 PM   #4 (permalink)
View 500KCamry's Photo Gallery
Son of a gun there's a lot of extra hoses on the air intake for California.
What he said above, take off the air intake to create working space. First relieve the fuel pressure, then loosen the bottom fitting on the filter, and then the top one (17mm). Once the fuel fittings are loose, loosen the bolts holding the filter to the fender.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 05-28-2009, 10:37 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Correct. Its a PIA to get the bottom line off.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 05-29-2009, 12:28 AM   #6 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Do what I did...
Get the mechanic to do it :P Do everything else yaself LOL, I tried many times... only way I could see was from underneath with someone helping at the top. Pain in the royal arse for sure.
whip_cracker is offline   Reply With Quote
Old 05-29-2009, 12:33 AM   #7 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
yeah...this was one of those jobs i let the mechanic do, simply because of lack of tools and patience... the fuel filter is a pain to work with.
one of the important things as mentioned is relieve the pressure...that can be done by removing the gas cap.
good luck!
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 05-29-2009, 12:56 AM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Sure, just to be safe, also crank the engine with the EFI fuse (5Amp) pulled. Leave the gas cap loose while working, and exercise all fuel related precautions (static electricity, water heater, etc)
good luck!
Old 05-29-2009, 01:02 AM   #9 (permalink)
There have been reports of the lower nut seizing and that results in twisted fuel pipe, and looks like you do have corrosion there. So follow what others said, PB Blast it and use the correct sized flare nut wrench.
In fact, if you have access to flare nut crowfeet, use a torque wrench to tighten. If you don't already have a torque wrench, the <$15 ones at Harbor Freight work well. You might need a small extension depending on crowfoot and wrench.
Again, PB Blast it and be very careful with that lower fuel pipe.
[quote=bud659;2735974]this is a first time thing for me trying to change the gas filter on a 1998 Toyota Camry 5f-SE 2.2l CAL emissions. i just dont want to get raped at the dealer.
Old 05-29-2009, 12:30 PM   #10 (permalink)
View Camry LE 94's Photo Gallery
Yes, follow what everybody here is saying. Me and a buddy of mine just spent 5 days replacing my fuel filter, reason being is that the bottom nut would absolutely NOT come off, which led to the kinking of my fuel line. In turn I had to buy a new fuel line from Toyota, which cost me $56.
So soak both top and bottom nuts with any type of bolt buster (I used Seafoam Deep Creep), disconnect the negative cable from your battery, remove the air filter assembly, loosen your gas cap to release any pressure in the fuel system (but remember to put it back on after finally replacing the gas filter, before starting your car.) Good luck!
Camry LE 94 is offline   Reply With Quote
