Lubricate strut mount bearings. Take off strut shaft's center nut and spray liberal amount of oil and see if it goes away. If it does, strut mount/bearings need to be replaced.
Inspect Swaybar links (thin rod with ball ends) that look like a dog bone, they usually clunk.
Suspension arm has bushings, spray some oil on and see if the noise goes away, if it does, then you know where the squeak is from and chances are, it will require replacement.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
