What parts can I take from 97' for my 92'? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2009, 02:24 PM   #1 (permalink)
WheresMyCar's Avatar
View WheresMyCar's Photo Gallery
3rd Generation What parts can I take from 97' for my 92'?
Any mechanical/electrical parts I could use off it?
97' 190k mi (bad suspension/exhuast/loud engine)
I'm switching so far:
Sun visors with extension flap
CD player + 6 disc Changer.
Full size spare. (mine had a flat)
92' has broken door handle cable(that releases door before pulling now = broken door handle also)
WheresMyCar is offline   Reply With Quote
Old 04-08-2009, 04:12 PM   #2 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
You may be able to swap the door handle, I'm pretty sure theyre the same, unless just extrenally.
Um, a majority of mechanical parts can be swapped as long as they're both the same engine.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 04-08-2009, 04:29 PM   #3 (permalink)
Thanks. They're both stock 4 cylinder engine Camrys
Old 04-08-2009, 04:32 PM   #4 (permalink)
TOYODA KAMURI
You definatly want the engine mounts. The gen 4 has thicker mounts that deal with idle vibration much better than the gen 3 counterpart. The majority of the engine componants are the same, I think the exhaust is different. Interior wise you can try your luck. It depends if there is anything you want to change.
Old 04-12-2009, 09:11 PM   #5 (permalink)
Anything else?
I wonder if the factory mud flaps will fit.
Old 04-13-2009, 01:00 PM   #6 (permalink)
View bjamick's Photo Gallery
Will the transmission out of a 93 4cyl work in a 97 4 cyl?
bjamick is offline   Reply With Quote
