Coolant flush: Do you remove engine block drain plug?
This is for my Camry 2000 4 cyl. I want to do a coolant flush. It seems there are two drain plugs/cocks: one is at the bottom of the radiator and the second is at the rear of the engine block.
Do you guys remove the second one too i.e the engine block rear one? Is it supposed to be difficult to get at? Or will jacking up the rear end of the car (so that car points downhill) achieve the same results?
Save yourself the hassle and mess and have a shop do it. I gave up doing my own flushes as it was just too much trouble for the return. Once you pay a shop about $70 to use their flush machine and get a thorough flush then just drain the rad once a year and refill with 50/50 pre-mix to keep the system clean and at proper ph.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Thanks to all who responded. If I were to connect a clear plastic tube to the engine drain plug to guide the coolant to a bucket, how much diameter one should I use? Would it be 3/8" ?
Or you could just drain the radiator, fill with distilled water couple times and keep draining until it runs clear--and then pour in full strength coolant. There is enough water in the block to mix with the coolant in the radiator to come out with a perfect mix (tested with a coolant tester).
If you add water with the method i described, you will dilute it too much.
Put the front of the car on jack stands and drained the radiator first. That drained around 4 qts. Then drained through the 10 mm engine drain plug and not a single drop drained. Same results even after flushing twice.
Coolant system capacity is around 8 qts. Where is the remaining 4 qts ? Do I have sludge in the car ?
Can someone tells me where my drain plug (cooling) on my the engine block?
I can't locate my drain plug when I am facing front of the engine..and looking on the right side ...where I assume the drain plug is located? Is the drain plug locate near distributor or what?
what size of bold should I look for drain plug (cooling) on my the engine block? where?
my car 96 Toyota Camry 4 Cylinder
Its a 10mm hex bolt and there is a small drain valve near it to which you can attach a vinyl plastic tube to drain the coolant (after loosening the hex bolt). On the camry 2000, it is to the rear nearer the driver side slightly.
first sry to resurrect an old thread. need a confirmation though. I'm about to flush radiator soon in 2000 Solara (or Camry Solara as some named it).
Do you think it is OK to drain old coolant through the radiator drain plug only? you wrote opening drain plug on rear of the engine block didn't produce even 1 drop after flushing radiator. I think I will flush it with distilled water a couple times and then refill with Toyota's pink 50/50.
a dumb question. what do you do with old coolant? dump it into sewers?
@fenixus:
Don't know about the technical question, but in NJ (and in most states, I think), coolant dumping is illegal. Usually the nearest recycling center will have a hazardous waste section where you can give them the old anti-freeze for free (up to a limit, like 10 gallons). Or you can pay your nearest auto-parts store to do it for you (though some only accept motor oil).
Quenizar, thanks for letting me know, you probably saved me a ticket ... although i've been living in states (different ones) for last 6 years, i'm still learning local rules and regulations LOL
you know, considering the problem with disposal and fact that i got no garage to perform the flush, i think i will bring it to the shop for cooling system flush ... will be much easier and safer for everybody
Yes, its okay to drain only through drain plug at front. You may flush it 3-4 times with distilled water first before putting in new coolant. Thats what I did.
I live in NY and around my place garages/auto shops don't take used coolants. I had to wait for a few months before I could turn in the used coolant at the spring/fall recyling event held by the county.
