92 camry 5sfe won't come out of park - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2009, 03:12 PM   #1 (permalink)
View cpt444@yahoo.co's Photo Gallery
Unhappy 92 camry 5sfe won't come out of park
hi guys!
i have a 92 camry wagon 188,xxx miles, that is stuck in park
ignition lock locks/unlocks, car starts - but cant depress the button to move the shift lever ... any ideas?
NOTE! in the past, on occasion, the car will not start unless I jiggle the electrical connector on the front of the transmission - where the shift cable and lever moves to select gears; think its somehow related?
i honestly think that has been strictly an electrical issue as its only the wires/connector that needs to be wiggled a little .... the car ALWAYS came out of gear when this happened.
{ i know i should open it up and clean the connectors in it; hopefully its just corrosion and not a bad wire! - anyone know how that connector releases?}
i am - or was - due to leave ny to go to nc in the early am .... 600 miles .... i guess it could have been worse than being in my driveway! but this is a major disappointment....
many, many thanks!
sincerely
cpt
cpt444@yahoo.co is offline   Reply With Quote
Old 04-17-2009, 03:46 PM   #2 (permalink)
SOLVED!!!!!! 92 camry 5sfe won't come out of park
when getting ready for the trip, I accidently yanked out the wire for the CB radio which was powered by the brake light fuse .... pushed the fuse back in tight - and
STARTED RIGHT UP!!!!
thanks
cpt
Old 04-17-2009, 03:59 PM   #3 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
In the future if this happens and you NEED to drive, there is a small plastic cover directly to the left of the gear shift. Just pop that cover off and use a screwdriver/knife/key to press the white piece of plastic in to unlock the gear shift.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
