94 Camry V6 to 4 CYL SWAP? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2009, 09:26 AM   #1 (permalink)
View Jonny Zero's Photo Gallery
Canada 94 Camry V6 to 4 CYL SWAP?
Is this do able? What does this entail? Has anyone successfully accomplished this?
There are so many 4 bangers and hardly any V6's in my area...
I am mechanically inclined, but I am also new to Toyota. Any advice, info, etc... that you have would be greatly appreciated.
Jonny Zero is offline   Reply With Quote
Old 04-18-2009, 10:24 AM   #2 (permalink)
I have swapped out motors in Hondas over the years, i'm just not familiar enough with Toyota yet to know.....
For the guy that said "there's something messed up in the water in canada...." Not a very bright guy. You Americans share the same water. I didn't come here to argue, I came for some genuine help.
Cheers
Old 04-18-2009, 11:40 AM   #3 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Should be similiar here with the honda motors. As long as the cam came with the v6 model you might only need to swap subframes, and mounts etc.
Check it out in the search though, this topic has been covered multiple times
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 04-18-2009, 06:37 PM   #4 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Very true. I come across way more 4's than the v6's. Why do you need to switch it though? Have you thought of just switching it with a v6 imported from Japan? Just had mine replaced actually and is running great! Has about 60,000km's on it. Running smooth and clean.
cykaaro is offline   Reply With Quote
Old 04-18-2009, 06:48 PM   #5 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
If you don't mind my asking how much was the engine and swap cyk?
ACCIDENT...
Thanks
Old 04-19-2009, 12:47 AM   #6 (permalink)
Canada
That's my whole question... There aren't many of these kicking around at teh scrapyards, but there are plenty of the 4 bangers.... What did ya pay @ The Jap store? $1000? I don't want to spend that much, hence, the 4 banger swap probability....
Old 04-19-2009, 12:47 AM   #7 (permalink)
PS I am so new to this forum, i would appreciate some DIY threads / links if anyone can help this newbie in need out?
Cheers
Old 04-19-2009, 01:10 AM   #8 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Go buy a Honda.
5 Lug Corolla WHAT?
Old 04-19-2009, 02:03 AM   #9 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Originally Posted by ASG14 View Post
Go buy a Honda.
ACCIDENT...
Thanks
Old 04-19-2009, 07:41 AM   #10 (permalink)
cykaaro's Avatar
Engine and parts were about $900+labour. The redid the seals [like rear main/oil covers, etc etc] Runs great, after a couple weeks oil is clean as can be still and no leaks. Really happy with it. My mechanic is really good. Only thing still left to do is customizing the oil pressure switch to add in a sensor for my pressure guage.
Old 04-19-2009, 08:36 AM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
what happened to the V6 that would warrant such a swap?? its doable but will be alot of work and likely as much as rebuilding a V6 motor...if it can be rebuilt. best solution was said. swapping the whole subframe would be easiest.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-19-2009, 09:35 AM   #12 (permalink)
cykaaro's Avatar
It's why I got the new engine. Blew the crankshaft Not worth rebuilding. Cheaper usually getting a good low mileage jdm engine. As for getting an engine here, I've not found one worth it. Usually from what I have seen a lot higher mileage than a jdm.
