99 camry oil pan resealing and other quotes from dealer. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2009, 04:37 PM   #1 (permalink)
View mnsweeps's Photo Gallery
My local toyota dealer in North Hollywood CA mentioned the oil pan is leaking and recommends pan resealing. He quoted $395 Is it that complex to do? I am not a car guy and have no idea..
if not the dealer who can do it ? Pepboys ? Sears auto ?
Okay here are 3 issues dealer said the car has and quotes.
1) Oil pan reseal - $395
2) Valve cover gasket - $170
3) Transmission oil pan - $140.
mnsweeps is offline   Reply With Quote
Old 04-19-2009, 04:57 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $251167
View 95PimpingCamry's Photo Gallery
That is way to much to pay to change an oil pan gasket. And never take your car to a place like PepBoys or Wal-Mart. I don't know about Sears. I would find a reputable independent garage to first determine if your oil pan is leaking (cause it sounds like the dealership is trying to scam you). If it is leaking ask the independent shop how much they would charge.
Find a good garage here:
http://www.cartalk.com/content/mechx/find.html
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 04-19-2009, 06:12 PM   #3 (permalink)
View 1996camry's Photo Gallery
that is way to much for just resealing oil pan job. I would chose independent car shop...click the link below then do a search "recommend machanic".
make sure you look location in your area and make few phone calls (compare price $ for the job). look for shop that specialty for your model. You also can read comments from other people.
I wouldn't go Sear to have them work on your car.
1996camry is offline   Reply With Quote
Old 04-19-2009, 06:58 PM   #4 (permalink)
Gameroom cash: $845900
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Sears is a shithole and hires people that can't even change a damn tire, ugh.
As he said, use an independant shop.
'95 Corolla AE101...
Old 04-20-2009, 10:46 AM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
Just for comparison... Last Wednesday, a co worker of mine (Milton, Ontario Canada) went to a Transmission repair shop, thinking it was ATF leak at the pan.
Trans shop was an independent (not franchise like AMMCO) gave him an estimate of $130 CDN including oil change.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-20-2009, 01:32 PM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
None of those are complex...the last two are trivial; the first is slightly more involved since it usually requires popping loose a bit of the exhaust system (assuming the car spent it's life in South Cali, 'tho, rust shouldn't be an issue, so the exhaust system thing shouldn't be a problem).
Would you *like* to be a car guy? For $50 in tools (floor jack, jackstands, trouble light, a basic 1/4" metric socket set, and a 30mm socket) and less than that in parts, you could do #2 and #3. Another $20 in tools and about $10 in parts, and you could do #1.
I'm also curious how the dealer came up with the three items. Unless they took the time to clean the oil off of the motor, there's no way they could've determined the pan gaskets were leaking -- often there's so much oil coming from the distributor seal or the oil seals behind the timing cover (which, since oil flows down and to the rear of the vehicle, ends up on the pans) that you can't figure out where the oil is coming from until you've completely cleaned the motor and then looked for new leakage.
