Brake Fluid Leak on Drivers side - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2009, 08:36 PM   #1 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
Grrrrrrrr!
I just stopped a leak on my Crown Vic with the brakes.
Now I have a slow leak on the drivers side right by the rear door.
Its a 1992 I-4 with 148K miles.
Any idea on a inexpensive fix? Do I need to replace the whole brake line? If So, where is a good place to buy it from and is it the REAR brake line?
I have no idea how the brake lines run on this car
Deadly Sushi is offline   Reply With Quote
Old 04-20-2009, 09:36 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
slow leak, check fittings and the rear brake piston (usually piston leaks at the seal) and get a refurb'd replacement.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-20-2009, 02:28 PM   #3 (permalink)
Well the leak isnt coming from the rear tire area. Its coming from the middle of the car on the drivers side.
What should I get to replace the line? I dont even know what brake line it IS. The rear?
Old 04-20-2009, 02:44 PM   #4 (permalink)
Darkside Cut Me!!!
If you can see which is leaking go to ToyoDIY and look it up
2004 RX330 Sport
2003 Cam I4 XLE
Old 04-20-2009, 03:29 PM   #5 (permalink)
thanks man!!!!
Now how do i know if the car has ABS??
Old 04-20-2009, 08:14 PM   #6 (permalink)
View Manny1337's Photo Gallery
Originally Posted by Deadly Sushi View Post
thanks man!!!!
you can always fly down a street and slam on your breaks, if they lock up its not abs =P or just look up for your model yr
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 04-20-2009, 08:32 PM   #7 (permalink)
I did. The VIN doesnt help. I usually work on Fords and Im not sure what the 92 Camry ABS looks like under the hood OR where it is. ANyone have any photos?
Old 04-21-2009, 08:02 AM   #8 (permalink)
xle has abs but the other modles it was an option. for the hell of it id try slamming on them going on the street =P if they lock up and you just skid down the street its not abs
Old 04-21-2009, 02:46 PM   #9 (permalink)
Darkside Cut Me!!!
Not a good way to find out when you already have a leak in the system.
Look for Chilton/Hanes Manual or a Toyota Factory service Manual
ABS unit will have a large aluminum block with lots (8) hydraulic brake lines entering /exiting between windshield washer reservoir and power steering reservoir
2004 RX330 Sport
2003 Cam I4 XLE
