Originally Posted by Myiagros
It has just been fishtailing, no bouncing at all. It feels as if it pulls left then goes right and it stays like that until I slow down to about 55-60.
Let someone drive your car, and follow behind it. Are the rear tires follwoning the front, or is there an offset ... is the car "dog tracking".
If the rear alignment is out, the rear end will steer the car if the road surface changes - smooth or rough road surface, and the traction changes, the car will seem to jump and be difficult to control.
If the car seems to be driving sideways - you need a 4 wheel allignment.
A suggestion for you to investigate.
If the car needs an alignment, take it in. They will tell you if any component is worn - they can't do the allignment before correcting - you can elect to fix it yourself and return or have them do it. Their estimate is usually close, i.e. there shouldn't be any costly unknowns.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
