Small Vibration in 99 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2009, 05:50 PM   #1 (permalink)
View maxima1274's Photo Gallery
I have started to notice that my camry vibrates when the car is idle. It just started a couple weeks ago. When I'm driving, the car is fine but when I am at a red light, there is vibration that is noticeable...any idea what's wrong?
maxima1274 is offline   Reply With Quote
Old 04-21-2009, 06:24 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Its normal basically. Mine does it more when the ac kicks in. Some people say that changing the engine mounts will help.
carsrus is offline   Reply With Quote
Old 04-21-2009, 06:44 PM   #3 (permalink)
Do not buy from
View Zviator's Photo Gallery
seafoam
Zviator is offline   Reply With Quote
Old 04-21-2009, 09:03 PM   #4 (permalink)
Any idea on how to replace engine mounts?
Old 04-22-2009, 02:43 PM   #5 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
find a repair manual of sorts...
but take some carb cleaner, or throttle body cleaner and do work.
slpr1mz is offline   Reply With Quote
Old 04-22-2009, 08:30 PM   #6 (permalink)
axhammer's Avatar
View axhammer's Photo Gallery
4 Cylinder tend to have more shake then a V6. Try cleaning your IAC port, that might help if you have carbon in the Throttle Body, Check your plugs if they are clean and gapped correctly (plugs are not always pre-gapped). I wouldn't change the engine mounts unless they are physically torn and damaged. I don't advise you to waste money, always do the cheapest thing first (basic tune up, air filter, plugs, wires, reset computer, fuel injector cleaner in the tank). I find that filling up with a tank of 91 is just as good as Injector cleaner because 91 tends to have more detergents. Shell or Esso has good stuff.
axhammer is offline   Reply With Quote
