99 Camry 340 Camshaft Code
Hey, i am getting a P0340. I reset the light, it came back after a short drive. I did a quick wiring test, it seems good, tight connection, the sensor has a 1210 OHM reading (the engine warm). I cleaned the sensor, and retighted it, reset and still I am getting a light. Reversing the wires makes the CEL come on right away. I do not have a scope and I am pretty sure the ECU is good. Should I replace the camshaft wheel as it says in the service manual, or the sensor? The sensor is within spec, but I want to change it, because it seems the easiest thing to do!
