Neutral Safety Switch on 94 Camry NSS from bottom or top? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2009, 08:28 AM   #1 (permalink)
View Microman's Photo Gallery
Need to R&R the Neutral Safety Switch today on a 4 Cyl, 94 Toyota Camry. Been nothing but headaches. Have read and printed threads on removing, and cleaning, and their successes.
Should this be done from the top? only?, should I conside working some from the bottom up? Most people only talk about moving the AT dipstick, and or the other Device that sits next to the battery (Air xxxx).
Also cleaning the NSS and using dielectric. What would you recommend for cleaning the inside. I took another one I had apart, and can see how gunked up they can get. Any grease cleaner work ok? Then the dielectric, should I just put a little on all the COPPER surfaces of the contacts. No need to use too much right?
Microman is offline   Reply With Quote
Old 04-25-2009, 09:02 AM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I wouldnt use too much dielectric grease. Too much will cause you problems.
As far as cleaners go, I would use electric cleaner. I would also think that it is easier from the top of the engine.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
