Girlfriend nailed by local shop (1993 Camry Timing Belt Service, 2.2L). $976?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2009, 02:33 PM   #1 (permalink)
View Chrisynd's Photo Gallery
Angry Girlfriend nailed by local shop (1993 Camry Timing Belt Service, 2.2L). $976?!
Hey guys,
Can anyone give me an opinion here? I feel like they are overcharging her but don't have much supporting evidence.
Here's what was done:
Full timing belt service
-timing belt, cam seal, crank seal, water pump, idler/tensioner, oil pump seal, accessory belts
-Charged $125 labor to replace oil pump seal upon my request, claimed to have to "remove the front of the car" to get to the oil pump seal. This is complete BS as far as I know. I thought it was an additional ~7 bolts to pop the oil pump.
Oil leak from Oil Pan gasket
-charged $125 labor to fix
VA State Inspection ($16)
They charged a total of $976, 7.5 hours of it labor at ~$75/hr and the rest in parts.
1993 Toyota Camry 2.2L, ~200k mi
Is this normal or what? Thanks guys.
Chrisynd is offline   Reply With Quote
Old 04-26-2009, 03:07 PM   #2 (permalink)
Do not buy from
View Zviator's Photo Gallery
Here's my reciept a few monthd ago, right before the engine blew.
Change timing belt package.
Replace timing belt, waterpump, replace thermostat.
Replace engine crank seal, camseal, oilpump seal.
Replace outside belts.
New Coolant.
Parts: $250.00
Labor: $100.00
Zviator is offline   Reply With Quote
Old 04-26-2009, 03:18 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
That seems to be about twice what my local garage would charge (not a dealership -- just a bunch of mechanics I give business to when I'm in a hurry or when a job is beyond my skills).
Even taking into account the profit upcharge on the parts, the parts bill seems awful high, unless they were Toyota OEM.
Funny thing, the oil pan bill doesn't seem out of line, assuming they actually dropped the pan and resealed. The rest, 'tho...it's almost like they just added together the "by the book" labor charges for all of the individual jobs, and didn't cut any slack for doing it all at once.
Old 04-26-2009, 06:11 PM   #4 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
At first glance reading the title I was like, what did they do to your gf??
This is complete crap man, and it's time to get out your tools and start workin on her car
I've been doing all this crap to my gf's civic for a long time now, and saved her an assload of money.
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 04-26-2009, 06:14 PM   #5 (permalink)
Strum's Avatar
View Strum's Photo Gallery
I read it that way too. Dirty minds think alike.
I can't believe the cost of the work. Even a dealership runs specials that are near what Camricer noted.
Mark
1993 Camry 6 cyl. (142K),
1998 Camry 4 cyl. (140K)
1996 Corolla (227K), 1997 Corolla (167K),
Strum is offline   Reply With Quote
Old 04-26-2009, 09:26 PM   #6 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
If they used OEM parts, then the price is not that far off. For comparison purposes, in 2001, I had an independent garage replace timing belt, drive belts, water pump, idler and tensioner for $698 CAD using 100% Toyota OEM parts (ie. $200 for 3.4 hours of labour and $498 for the parts).
In your case, you have three more lip seals and one oring seal. My guess is $60 in seals and about 1.5 hours labor max. In addition, you need to add the oil pan gasket and labor to change it. I have not done this, so cannot speak intelligently about that cost.
The part that puzzles me is the $125 labor to change the oil pump lip seal and oring seal. It's only 7 bolts to remove the oil pump. In my opinion, that should only add about 20-30 minutes max. And the part about removing the "front of the car" is ridiculous. The oil pump is easily accessible when changing the timing belt. You would have ligitimate grounds to question this.
It is my experience that the $200 dealership timing belt specials are meant to lure people in the door. They only include the timing belt and nothing else. Once they got you in the door, they heavily upcharge for the water pump, oil seals, etc.
If you really want to pursue this, I would recommend calling an independent garage and a local dealer for an estimate to do the work that you have just had done and use this for comparison purposes.
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 04-27-2009, 04:50 AM   #7 (permalink)
View 500KCamry's Photo Gallery
The oil pan does have a premade gasket, its a silicone bead. The exhaust pipe under the pan has to be removed. A couple of pan bolts are difficult to reinstall without cross threading. Oil drain and refill. 1 to 1.5 hours to drain, clean the pan, clean the mating surfaces, layound the bead, reinstall and refill.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 04-27-2009, 05:12 AM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Tell me what shop in Richmond did this to your GF and I'll be sure to never go there!!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 04-27-2009, 08:13 AM   #9 (permalink)
hill8570's Avatar
OTOH, "book time" on an oil pan R&R is like 3.5 hours. Lord only knows why -- the timing belt change only books at 3...
Old 04-27-2009, 10:57 AM   #10 (permalink)
View jmborchers's Photo Gallery
Just did this similar job on 99.
Didn't do the oil pan gasket. The oil pan gasket was good on mine. Leak was at the head cover gasket.
If you got new dealer parts that's a fair price IMHO.
jmborchers is offline   Reply With Quote
Old 04-27-2009, 10:59 AM   #11 (permalink)
After some mild questioning of the price, they knocked off $100 from the total when I went with her to pick it up; due to "price confusion" from earlier price discussions that differed from totals - bringing it to $876 out the door. Popped the hood and a timing belt cover bolt was missing near the top... Ugh.
There were 3 different oil pump related seals on the receipt, an "oil pump gasket", an "oil pump seal" and an "oil pump housing gasket". There's 3? Parts were not OE, they were from the Pep Boy's literally a stone's toss down the street I assume.
The receipt didn't break the labor down by job/part, it was simply chunked to 7.5 hours so I couldn't tell where things seemed high. Shop was Standard Auto Center on Nine Mile Rd. in Richmond, VA.
Thanks for the replies guys, it hasn't blown up yet. Sadly the alternator was covered in oil due to the oil leak, betting that will go soon...
Old 04-27-2009, 11:44 AM   #12 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
later this year i'm getting my water pump changed, timing belt changed, and the whole front end of the engine fixed up for $400.00
deezeejoey is offline   Reply With Quote
Old 04-27-2009, 12:35 PM   #13 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
The title of this thread made me think it was related to a porno...
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 04-27-2009, 12:59 PM   #14 (permalink)
hill8570's Avatar
Yup, there's a gasket where the oil pump mounts to the block, an o-ring between the two halves of the oil pump, and a seal where the shaft for the oil pump pulley comes out of the pump.
Old 04-27-2009, 01:32 PM   #15 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Bow chicka bow wow
ACCIDENT...
Thanks
