Power window not working! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2009, 08:26 AM   #1 (permalink)
View josht913's Photo Gallery
4th Generation Power window not working!
I rolled my windows down friday, and went to put them back up and heard a loud popping noise coming from the right rear door, and I noticed that my window isn't coming up. When I got home I took the door panel off, and it seems like the "teeth" are not lining up if that makes sense. I can hear the motor "humming" when I use the switch so i'm guessing the motor is working.
Also if I move the piece with the teeth just right it will catch and roll up/down just a little but will fall back down.
Does this sound like a regulator issue?
Any help is appreciated.
Thanks.
josht913 is offline   Reply With Quote
Old 04-27-2009, 11:17 AM   #2 (permalink)
Anyone have any ideas?
Old 04-27-2009, 01:22 PM   #3 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Sounds like the regulator. I got a motor/regulator combo on Ebay a few years ago when the LF failed and it's been fine since.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
Old 04-27-2009, 03:27 PM   #4 (permalink)
I appreciate it. Hopefully it won't be terribly difficult to swap out.
Thanks again.
Old 04-27-2009, 09:46 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Pick up a regulator/motor combo from your nearest wrecker. I just replaced my LR about 3 weeks ago for the same problem you mentioned. You will most likely find the cable frayed and unwound from the motor pulley. Be sure to grease the cable and guides with lithium grease.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 04-28-2009, 09:35 AM   #6 (permalink)
Yeah, I figured that I might as well do the motor too since i'll be in there. I don't wanna end up having to do the same thing over a couple weeks/months down the line.
Thanks again!
