4 Cyl Engine blowby
I have a 93 4 cylinder camry with 141K miles that seems to have a lot of blowby coming from the oil fill cap when I pull it off while the engine is idleing. Is this normal?
I am not having any other problems, no oil leaks, no oil consumption, no valve noise. I was originally thinking it might be a head gasket but I am not convinced its abnormal. THe PVC seems to be functioning normally though I will put a new one on today just cause its cheap. I will try to pick up a compression tester this week but since I'm not using any oil or blowing smoke I don't really think that is the problem.
Any thoughts or experience on what might be causing this or if its normal would be appreciated.
Mike C
Evergreen Colorado
1993 Camry - 2003 Tundra - 2005 Sienna
