I have had replaced new cover gasket on my brother Toyota 2000 4 cylinder, but I still have small leak near the transmission side and the corner on the distrubutor side.
Jeff, I look at the manual link on this page above... still has a question... It is necessary to apply seal packing to semi-circular? Refer to page 57 on the manual link above... Where is the semi-circular? is that locate near the distruutor side? how do you remove it? how do i remove it? Is that the cause leaks on distrubutor side?...
What cause the leak on the transmission side after replaced new cover gasket?
someone has done this before and has experience on cover gasket to share your expert and thing to avoid and thing should do..
Reason: fix typo
