Engine won't start after pulling out the spark wire from distributor while running - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2009, 02:32 PM   #1 (permalink)
View Baganmin's Photo Gallery
My 93 Camry was running fine except for rough condition at the idle position. The engin was very easy to start before anything that I repaired. I pull out no. 2 spark wire from the distributor while the engine was running. The engine stalled at about 5 sec. and after that I couldn't start the engine anymore(cranking but no fire). So, I pull out the spark wire and checked any spark with engine cranking. No sparks comming out of the wire. What was cause the distributor died right away and how should I troubleshoot the problem. Thank you in advance.
Baganmin is offline   Reply With Quote
Old 04-29-2009, 02:47 PM   #2 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Why did you do that?
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 04-29-2009, 03:03 PM   #3 (permalink)
I try to troubleshoot the engine rough problem, so I want to make sure the distributor doesn't cause that problem. Now I got two problems. Thanks.
Old 04-29-2009, 03:07 PM   #4 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Ugh, that wasn't the best way to troubleshoot ya know?
Replace plugs, wires, dist cap & rotor, seafoam tb & brake booster, and go from there.
ACCIDENT...
Thanks
Old 04-29-2009, 03:08 PM   #5 (permalink)
Gameroom cash: $303255
Check the coil inside the distributor. You will need a digital volt/ohmeter and the specs from any manual to do this. Running the engine with a spark plug wire off a plug may be just enough to kill a weak coil.
Mike
Old 04-29-2009, 03:11 PM   #6 (permalink)
Will do.
Old 04-29-2009, 03:11 PM   #7 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Mike
That would probably be his newly acquired "second problem"
ACCIDENT...
Thanks
Old 04-29-2009, 10:13 PM   #8 (permalink)
Sure it is. I replaced new coil and it started right away, but I still had the first problem. The engine vibrates and rpm not stable at the idle position. Thanks.
Old 04-29-2009, 10:45 PM   #9 (permalink)
View 1996camry's Photo Gallery
remove and clean your intake to prevent the idle RPM not stable.
1996camry is offline   Reply With Quote
Old 04-30-2009, 11:44 AM   #10 (permalink)
Clean your throttle body on the car, paying particular attention to spraying the cleaner liberally down in to the square or diamond shaped port at the base of the throttle body. That port leads to the idle air control valve, where your problem may exist. Then go on to clean up the rest of the throttle body. Here's a link to a DIY thread with great pictures that explain the process.:
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Mike
Old 05-02-2009, 10:20 PM   #11 (permalink)
Mike
I cleaned the throttle body, but the problem still exists. Error code 71 just came up today. Thanks Mike.
