97 camry REAR speaker intallation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2009, 03:07 PM   #1 (permalink)
Chivaspro's Avatar
View Chivaspro's Photo Gallery
Angry 97 camry REAR speaker intallation
IM having problems taking of the rear speaker covers do i need to take off the whole rear cover?
Chivaspro is offline   Reply With Quote
Old 04-29-2009, 09:50 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Doesn't the entire rear shelf has to be lifted up a bit for access? I think there were DIYs somewhere.
Old 05-02-2009, 01:33 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349253
View BMR's Photo Gallery
Yes, the entire rear deck cover has to come off. I did a rear strut R&R thread (link below) which shows how it comes out. Basically, you have to remove much of the rear seat before you can pull the cover.
Link
BMR is online now   Reply With Quote
Old 05-02-2009, 06:05 PM   #4 (permalink)
View frojoe's Photo Gallery
Yes the whole rear deck has to be taken out, but to take the rear deck out the rear seat needs to be removed, and then the two strips of seat-back by each door. Its a pita.
frojoe is offline   Reply With Quote
Old 05-05-2009, 09:27 AM   #5 (permalink)
View Yanpapa's Photo Gallery
speaker Installation
Here is a site that I've used before to replace my speakers.
http://www.gearmonkey.org/sixthman/a...34.html#001934
97 Camry LE 4 cyl. 5S-FE 160K miles
10 Corolla LE 15K miles
Yanpapa is offline   Reply With Quote
Old 05-06-2009, 12:38 AM   #6 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
- Take out bottom part of rear seat (held in by a couple of clips.
- Use socket set to remove one bolt either side of rear seat next to seat belts... slide the side piece up and off.
- Fold rear seats down..
- Undo a couple of screws that hold the deck on the car... normally located on the deck behind the rear seats when folded down.
- If you have a grandpa rear light on parcel shelf, unclip that (screwdriver or sumfin), disconnect...
- Pull the deck off :P
Should have full access to the rear speakers.
whip_cracker is offline   Reply With Quote
