Strange Issue with Gen 3 Camry.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2009, 04:43 AM   #1 (permalink)
View junkofdavid2's Photo Gallery
Exclamation Strange Issue with Gen 3 Camry..
I have 2 questions regarding my Gen 3 Camry.
1) My airconditioner button started flashing and the coolness just stopped (only fan was blowing). I pressed the button to shut it off. Pressed it on again after about 30 seconds, and the airconditioner was working perfectly fine again. What was that???
2) What's that tiny button on the automatic shifter lever? Not talking about the ECT button at the base of the shifter... I'm talking about the tiny button on the shifter itself? Only noticed it now...
junkofdavid2 is offline   Reply With Quote
Old 05-01-2009, 05:37 AM   #2 (permalink)
abe88's Avatar
View abe88's Photo Gallery
that button you're talking about is the O/D button or overdrive, it turns overdrive on or off. Go to this link for more info on that.
As for the AC, thats the first ive heard about the button blinking, maybe you have a loose wire or something, if it happens again its either ur car telling u you're out of compressor gas (unlikely) or a loose wire
Welcome to the forum btw, check out the FAQ section next time theres alot of info there that you might find interesting.
abe88 is offline   Reply With Quote
Old 05-01-2009, 08:31 AM   #3 (permalink)
View 05DCLB's Photo Gallery
There is an improved a/c MG CLUTCH relay to fix the flashing a/c button. It is in the underhood fuse box and the new part ends with 028, the bad one ends with 022. Very common problem and should be around $60.00 for part. Let me backpeddle a bit, this is for 2002-2004 Camry's
05DCLB is offline   Reply With Quote
Old 05-01-2009, 10:00 AM   #4 (permalink)
I'm aware of that symptom for the newer camrys... but I'm not sure if that applied to Gen 3 camrys like ours...
Old 05-01-2009, 11:32 AM   #5 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
The flashing A/C light means that something was sensed that had a significant chance of cratering your compressor (pressures too high or too low, probably some other things...don't have the FSM in front of me), so the magnetic clutch is disengaged to shut down the compressor. May've just been a glitch. Pretty difficult to troubleshoot unless it starts happening on a more regular basis.
Old 05-01-2009, 11:39 AM   #6 (permalink)
View hoiskii's Photo Gallery
A/C blinking happened to me in heavy rains several times. This happened not only with my camry but with other cars too.
Are there any special conditions under which this blinking occurs?
99 I4 Camry LX
hoiskii is offline   Reply With Quote
Old 05-01-2009, 11:52 PM   #7 (permalink)
View timothyl2184's Photo Gallery
The blinking light is the same problem I'm having with my 96. It started with just once like you, then every few days, then to where we are now with all the time
timothyl2184 is offline   Reply With Quote
Old 05-02-2009, 02:34 AM   #8 (permalink)
Does it work fine again, right after you switch it on and off?
Have you consulted with any garage/dealer about this?
Old 10-28-2009, 07:57 AM   #9 (permalink)
GEN 3 at 265,000
View Mike6412's Photo Gallery
USA
I just had the same thing happen to my 96 Camry. I was sitting at idle on a cool morning keeping the defroster on. I noticed it getting real muggy in the car then seen the a/c button light flashing. I turned off a/c waited 30 seconds then back on and everything worked fine. I have noticed here lately that I am getting bubbles in the liquid line sight glass. I am charging up the system some this weekend.
My new ride is a 1996 Camry I4 265,000 miles.
Also 2001 Mazda MPV, and 2007 Kia Sadona.
Mike6412 is offline   Reply With Quote
Old 10-28-2009, 10:31 AM   #10 (permalink)
Gameroom cash: $303255
It may also be as simple as a loose a/c belt slipping on the compressor. That will shut down the compressor. Check the belt tension.
Mike
Old 10-28-2009, 02:17 PM   #11 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Mike
I believe this is what happens to my car when I drive over deep puddles in heavy rains. Seems like the belt gets wet, button flashes, and A/C dies... and sometimes it can take up to a couple of minutes for the A/C to kick back on.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 10-28-2009, 04:00 PM   #12 (permalink)
It will probably kick right back on if you shut the a/c off, then shut the car off. Then restart it and then turn the a/c back on.
Mike
Old 10-28-2009, 04:18 PM   #13 (permalink)
Gameroom cash: $160515
View mdatrdcam's Photo Gallery
yup, same thing happens to my 96 when i go through a large puddle or its raining heavily. i just turn the a/c button off for about a minute and then back on. everything works perfectly after that.
FULLY LOADED 01 V6 5-SPEED-INJEN INTAKE-TRD QUICKSHIFTER-FULL TRD SUSPENSION-TRD STRUT TOWER BAR
mdatrdcam is offline   Reply With Quote
Old 10-29-2009, 04:03 AM   #14 (permalink)
Mike
I can't say for sure that I have tried that exact process of turning off the A/C then shutting the car off. But I know that I have shut the car off before and it did not come back on immediately. It still took a few moments. I specifically recall an incident this year in New York City where the rains were causing flash floods in some areas, and it took forever for the A/C to come back on (several minutes after driving through deep water). Almost to the point of really pissing me off.
Old 10-30-2009, 05:36 PM   #15 (permalink)
View Dick Tuck's Photo Gallery
Water makes the belt slip which triggers the blinking light. Had the problem which went away when I changed the worn streched belt.
Dick Tuck is offline   Reply With Quote
