suspension rattle/knocking sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2009, 08:28 AM   #1 (permalink)
yota=good
View Morley's Photo Gallery
So I've ran a search and found some threads but not sure if its the same thing I'm getting.
Basically, when driving in the city and going over manholes, bumps etc, the suspension seems to make this kind of knock knock knock sound... almost like a ratle knocking sound.
I've replaced all 4 struts/coils/strut mounts last weekend.. Replaced with Munroe Quick struts.. Which I highly recommend btw.
Can anyone help me isolate if this sound is the swaybar end link or sway bar bushings?
Appreciate the help.
Morley is offline   Reply With Quote
Old 05-01-2009, 10:10 AM   #2 (permalink)
View warlock's Photo Gallery
I had a simalure prob. Turned out to be the upper strut mount bushing. But u might want to cheak and make sure the spring is properly set in the strut
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 05-01-2009, 11:39 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Like you said, if the noise is coming from the rear suspension, its going to be either the end links or the RSB bushings. Did you use new upper mounts for the struts?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 05-02-2009, 02:25 AM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
depending on where the sound is commin from...id point to the rear sway bar links as well among a few other things.
dude...blast from the past. long time no post!!
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-02-2009, 10:30 PM   #5 (permalink)
Yes it is. I had some life issues needing taken care of and only way was to drop a lot of things for a time. But well I'm back might not be as active as I was but I'm here.
As for the noise he didn't say it was the rear. But if it is coming from there I'd cheak the sway bar. Mainly the bolts and the closest bushings.
It could also be the tye rods or lower ball joints if its coming from the front.
94 Scepter 1MZ-FE
Old 05-03-2009, 04:02 AM   #6 (permalink)
View unique7's Photo Gallery
My car has/had the same problem. I think they all do. Exactly like you described with the rattling and knock knock sound.
I changed the back struts, it doesn't make the noise as often but it is still there. But a little bit of noise on such a old car doesn't worry me.
unique7 is offline   Reply With Quote
Old 05-03-2009, 09:43 AM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
I don't think the end links would make that loud of a noise, possibly the bushings though.
Make sure the strut mount is tighten all the way to proper torque specs.
Sometimes it's the strut bearing plate that's underneath the strut mount itself.
Are you sure its not the exhaust that came off a hanger possibly and is knocking into the chasis?
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
