Try hooking it up to the stock crossover first. Mount up the speaker with a couple of screws and test it. If you are getting highs in your woofers or lows in your tweeters, you should notice some distortion in the sound. Chances are good it will work fine. If not, check for the stock crossover behind the factory head toward the passenger side. Trace the speaker output wires if its hard to see.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
