check engine light help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2009, 11:53 PM   #1 (permalink)
View mpmarypat's Photo Gallery
4th Generation check engine light help!
Hey, I have a 1997 Camry, 4Cyl., in good shape, 148,000 miles. The check engine light came on, so I took it into Goodyear. They said the computer said emissions control duct??? does this make sense? It's been losing some coolant, but I thought that might be water pump.
They reset the light, it came back on a week later after having been driven all week.
Any ideas what I should have them check at the mechanics??
Thanks for any help..
mpmarypat is offline   Reply With Quote
Old 05-04-2009, 10:44 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
The description doesn't match up with any diagnostic I'm familar with. Any idea what the exact code (Pxxxx) was?
BTW, other than a couple of temperature sensors, there isn't a lot in the cooling system that will trigger a check engine light. If you're losing coolant, that's probably worth tracking down.
Old 05-04-2009, 11:25 AM   #3 (permalink)
Smile Thanks!
Thanks for responding. I'll try to get the code from the guy at Goodyear. I was out of town and a friend took it in so that's why I don't have the info.
The coolant thing is a mystery. I had someone earlier this year talk about the water pump maybe being the culprit, I don't think it's been changed for many years - but when I had the timing belt replaced about 6,000 miles ago, noone explained it was best to do the pump then!!
Also, the coolant doesn't always go down, just every once in a while.
I will get the code and write again if you wouldn't mind. I appreciate the help as I don't know a heck of a lot about all this!
Old 05-04-2009, 01:24 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
EGR pipe/duct??
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-04-2009, 01:56 PM   #5 (permalink)
Smile Thanks!
Thanks for writing. I'll have them check that. I know very little about all this -- so every little bit helps!
