Mechanics ripping me off ...Plzzz help ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2009, 09:45 PM   #1 (permalink)
View vikingz999's Photo Gallery
Unhappy Mechanics ripping me off ...Plzzz help !
Hello Experts,
I hope this post finds you all in the best of your health.!
I have an issue with my 2001 Camry i4 and I am sure you folks have probably seen it a lot.
Its a check Engine Light and the Error code is P0420.
I got the error code and it talks about Catalytic converter ...low efficiency....something ( i dont remember the whole description)
But.... i have had mechanics change the smaller catalytic converter twice...its goes away for 300 miles and then come back when its raining / just finished raining and its all wet on the road....... or its pretty humid. I see the engine rev up a very tiny bit.
But the issue is i have had 2 mechanics do the same thing and the darn light keeps coming back. I dont know what to do and where to do....honestly i am kind of financially struggling so dealership would be a bit harder option.
Please suggest whats wrong...!
Thanks.
Vikingz
vikingz999 is offline   Reply With Quote
Old 05-05-2009, 01:01 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Hey Vikingz, I moved your thread from the intro section to this Camry forum.These guys can help you.
Good Luck and Welcome to ToyotaNation
The Jedi Speeder at CarDomain
Old 05-05-2009, 05:21 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
http://www.obd-codes.com/forums/view...php?f=1&t=4801
Looks like similar problem except for the rain thing.
More P0420 Toyota code info: http://www.obd-codes.com/forums/view...php?f=6&t=4255
The rain may be shorting out the O2 sensor wiring causing a false code trip?? Two bad CATS (if new) in a row is remote.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-05-2009, 06:27 AM   #4 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I'd say the same as stillrunning ^.
P0420
Catalyst System Efficiency
Below Threshold
(Except California Spec.)
 Three–way catalytic converter
 Open or short in heated oxygen sensor circuit
 Heated oxygen sensor
P0420
Below Threshold
(Only for California Spec.)
 Three–way catalystic converter
 Open short in heated oxygen sensor (bank 1 sensor 2) circuit
 Heated oxygen sensor (bank 1 sensor 2)
 Open or short in A/F sensor circuit
 A/F sensor
5 Lug Corolla WHAT?
Old 05-05-2009, 08:39 AM   #5 (permalink)
View jmborchers's Photo Gallery
Pull FreezeFrame
The mechanic needs to pull the engine freeze frame data with the code to understand what is occuring.
jmborchers is offline   Reply With Quote
Old 05-05-2009, 10:41 AM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
The oxygen sensor downstream (closer to the tailpipe) of the catalytic converter is used to monitor the efficiency of the cat. Two bad cats in a row are unlikely, and the correlation with rain makes it most likely a wiring issue -- probably a connector or connector boot that's letting in water. Since the farking downstream O2 sensor is under the car (between the cat and the muffler), and is routed to the engine compartment in the most bizarre way possible, it's easy to see how that could happen. I'd check the wiring and connectors coming from the downstream O2 sensor. See http://www.camrystuff.com/manuals/Gen4/SFI.pdf starting on page 62 to get a decent idea of the area we're talking about (sensor 2 is always the downstream sensor, and the 4-banger only has one bank, so you're looking at Bank 1 Sensor 2).
Old 05-05-2009, 02:49 PM   #7 (permalink)
JSloan
View sloanj1's Photo Gallery
If the cats have been replaced with one of those cheap "one size fits all" cats, that can very well be the issue. Toyotas are very sensitive when is comes to emission controlling parts. Unfortunately the Toyota cat is very pricey. As for the rain affecting it, I would lean towards a wiring issue.
sloanj1 is offline   Reply With Quote
Old 05-05-2009, 04:00 PM   #8 (permalink)
Its not really the rain. Its the rainy season, all moist roads , humidity in the air with wet roads ( kind of like ..how you roads look like with water on them after rain).
Do you think that would have caused the issue?
The first time it came on was in Arizona super hot dry....(I replaced the smaller cat after an accident...the catalytic converter started clanking and banging...so the dude said replace it...after 300 miles o the arizona highway Santa gave me a visit.....SURPRISE !!!!!!!!!!!! CEL-P0420 !!!!!!!!
I love my car..never stood me up.. but this orange colored devail makes my heart break !!!!
Old 05-05-2009, 04:29 PM   #9 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
Has the second O2 sensor been replaced? Perhaps the first mechanic destroyed it when replacing the cat, and replaced it with a cheap one to save money. Those cheap O2 sensors will usually throw a cat efficiency code on Toyotas.
SexieWASD is offline   Reply With Quote
Old 05-05-2009, 04:49 PM   #10 (permalink)
Oh yes I forgot to mention:
The car has 71,000 miles on it.
Also the previous 2 cats (smaller one) under the car ( not the one closest to engine) were cheap ones. Cuz the mechanic only charged me 75 bucks for everytime.
Old 05-05-2009, 04:51 PM   #11 (permalink)
SexieWASD,
I dont think he replaced the second O2 sensor.
Maybe messed it up but i dont think he changed it.
Because he didnt mention changing the sensor or else he would have charged me for that one too.
Old 05-06-2009, 02:35 PM   #12 (permalink)
JSloan
Check the rear O2 sensor/wiring. But if the cats were cheapys, that can definitely cause an issue.
Old 05-06-2009, 06:58 PM   #13 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i dont know how the cat(s) are monitored on an '01 i4 camry, but on my '96 i4 camry there are two cats and only the primary (large one by the engine) is monitored. when i got the 0420 light, i could change the second one all day and it wont make a difference until i changed the primary cat. FWIW.
Old 05-07-2009, 06:50 AM   #14 (permalink)
Now that you mention it I think your right, I'm too lazy to double check, but I think only the main cat is monitored.
Old 05-07-2009, 10:35 AM   #15 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
ur cat is not the problem. it has to be the o2 sensor. check the wires if the wires seem fine i would take the sensor out and see if the mechanic got any anti seize on the tip. if theres sumthing wrong wit the sensor always get OEM o2 sensors. never get universal, they always give cars problems and are not reliable.
project92camry is offline   Reply With Quote
