dumb question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2009, 01:08 AM   #1 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
dumb question
what psi do i fill the tires to?
allmoast all f the stickers are sunbleached
its got the aluminum wheels idk if that makes a diffrence
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 05-06-2009, 01:46 AM   #2 (permalink)
MIK1989's Avatar
View MIK1989's Photo Gallery
What kind of tires are those?
32 psi is the standard pressure for Toyota Camry, but everyone has their own preference. I fill up to 34 psi.
Toyota Camry XLE 1997, V6 (1MZ-FE)
MIK1989 is offline   Reply With Quote
Old 05-06-2009, 02:27 AM   #3 (permalink)
quangtran89's Avatar
iTrader Score: 8 reviews
View quangtran89's Photo Gallery
32 is good. 35 if you have a truck or SUV tire
quangtran89 is offline   Reply With Quote
Old 05-06-2009, 06:22 AM   #4 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
^32 psi seems about right to me
RU2CHKN is offline   Reply With Quote
Old 05-06-2009, 06:50 AM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
its written on the side of your tires...."max PSI"....I do 35 myself!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 05-06-2009, 07:12 AM   #6 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
I run 35-36... guess it depends on the weight you're carrying ay?
whip_cracker is offline   Reply With Quote
Old 05-06-2009, 08:48 AM   #7 (permalink)
View Simpler=Better's Photo Gallery
I run my tires at 44, the rating is molded into the sidewall.
1994 Camry I4 (Temporarily)
1982 Mercedes 300D (Summer)
Simpler=Better is offline   Reply With Quote
Old 05-06-2009, 09:05 AM   #8 (permalink)
well the max psi on theise say 52 psi that must be way to high
i guess 40 psi wouldnt do any harm right?
Old 05-06-2009, 09:57 AM   #9 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
my 98 CE with 195/60/14 tires are labeled at 28 psi front and rear.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-06-2009, 10:17 AM   #10 (permalink)
Super Moderator
eyeball96's Avatar
I drought they say 52psi...I have 225/55/20's on the GMC and max on those are 44 psi...I run 37-40 psi
http://www.firestonecompleteautocare.../inflation.jsp
98 Honda CRV
08 GMC Crew
Old 05-06-2009, 04:01 PM   #11 (permalink)
Well, if you over-inflate, the tyres will start to round more... then you'll wear the inside of the tyre more mate.
Underinflate, and you'll wear the sides out... hahahaa
Inflate to the right pressure, rotate the tyres when needed, and you'll be fine.
Old 05-06-2009, 05:04 PM   #12 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
I prefer 34 in the rear and 32 in the front, it seams to give the car a more balanced feeling, not that camrys are at all balanced. My rear tires do wear a bit round though.
SexieWASD is offline   Reply With Quote
Old 05-09-2009, 08:46 PM   #13 (permalink)
View flyeri's Photo Gallery
32-34 lbs cold is pretty normal. I used to run about 35 cold and would always wear the center tread quicker than the outside treads. I have a pressure monitors on my vehicle now and I try to find a cold temp that will give me no more than 37-39 lbs when hot. Of course they heat more in the summer than in the winter so my cold pressure in winter is slightly higher than summer.
Edit: Once I learned just how much pressures increase with heat from driving, and I adjusted accordingly, the tire wear is much more even. The car manufacture's numbers are what you should go by (normal driving) and any large variance will usually cause poor tire wear.
flyeri is offline   Reply With Quote
Old 05-09-2009, 10:27 PM   #14 (permalink)
Lurker
View 8ac1v1c's Photo Gallery
No matter what the tire says - you inflate according to the vehicle.
Tires are the Same on any vehicle but each vehicle has different specs and weight.
I'm pretty sure it's 32 front/rear Ill double check tomorrow
For those of you wearing out in the middle - you're over inflating
For those wearing out on the outside - it's under inflated....or you can some alignment issues
8ac1v1c is offline   Reply With Quote
