TN mechanics i need you help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2009, 08:22 PM   #1 (permalink)
View kidxrobot's Photo Gallery
ok so i have a 98 camry approaching 200k ..... and it seems that i cannot re start my car after turning it off wit out it sputtering if or me having to give it gas if it hasnt been an hour or so. i did some searching and i thought it was the IAC valve so i took that throttlebody apart and cleaned it (followed the DIY from here) and still nothings changed what do you guys think?
kidxrobot is offline   Reply With Quote
Old 05-06-2009, 08:39 PM   #2 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Your IAC valve should be fine... I'm guessing you have a 1MZ V6? The only time I had to clean my IAC valve on my 3VZ was when I had sporadic idling problems... looks like it wasn't getting the air it needed.
How long until you need to take your foot off the throttle? It runs fine after it's started and running I'm guessing?
whip_cracker is offline   Reply With Quote
Old 05-06-2009, 08:50 PM   #3 (permalink)
yea its a v6. i m on the throttle maybe 1-2 seconds im guessing jus 2 quick revs of the engine and its fine but this is only after ive been driving. on a cold start IE the morning it stars just like any other car
Old 05-06-2009, 08:55 PM   #4 (permalink)
Maybe just getting the fuel to pump through to the injectors is taking the time...
How about starting warm?
Old 05-06-2009, 09:25 PM   #5 (permalink)
starting warm is the problem jus yesterday i had been driving for maybe an hr i parked shut it off and had 2 restart to straighten out. and when i tried to restart it sputterd and shut off completley
Old 05-06-2009, 09:49 PM   #6 (permalink)
Hm... weird.
Unless you have a problem with fuel getting to the engine (pump, filter, injectors etc) then you shouldn't have that happen.
Has it happened before, or once only?
Old 05-06-2009, 09:56 PM   #7 (permalink)
yea its been a consistant problem
Old 05-06-2009, 10:07 PM   #8 (permalink)
I'm no mechanic, but I'd first be looking at the fuel pump (under rear seats normally) or the fuel pump. It doesn't explain why the car works fine after an hour though. One of the other lads will know
Old 05-06-2009, 11:34 PM   #9 (permalink)
engineer in training
Gameroom cash: $145055
How well has the car been maintained? Air filter, plugs that sort of deal.
Try getting some electronic parts cleaner from an autozone and cleaning the maf sensor.
