Burning Smell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2009, 01:37 PM   #1 (permalink)
Junkyard Junkie
Chris Crash's Avatar
Gameroom cash: $746337
iTrader Score: 10 reviews
Burning Smell
I think my 97 4 cylinder is leaking oil. I have tried using the special dye and a black light, but I didn't find any leak. The reason I think it's leaking is that every time after I drive and it gets warmed up completely, when I get out and turn off the car I can smell a burning smell. It definitely smells like burning oil. Also, if I have the A/C on at a stop light, the smell starts coming through the vents.
I replaced the valve cover gasket, to no avail.
What is this mystery burning smell?
Am I burning clutch fluid? I don't think so. I'm not slipping the clutch more than normal use so I don't think it's the clutch burning, either.
You can see oil down the back of the engine, everywhere. So it is impossible to trace where it starts because this car has had a lot of problems with the engine, so like I said, there are oil stains and buildup everywhere.
Chris Crash is offline   Reply With Quote
Old 05-10-2009, 05:39 PM   #2 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Degrease and powerwash your enigne to clean it up so you can better tell where the oil is coming from. Two places to check are the oil filter adapter and the distributor. On my V6 both were leaking. The first was causing it to drop on the manifold and burn off causing the burning oil smell to come into the car, as well as it woud smoke a bit. Good luck.
cykaaro is offline   Reply With Quote
Old 05-10-2009, 06:14 PM   #3 (permalink)
View dans01camry's Photo Gallery
Is your parking brake on . Happened to a friend of mine .
dans01camry is offline   Reply With Quote
Old 05-10-2009, 06:56 PM   #4 (permalink)
Junkyard Junkie
No. It's been having this burning smell for a long time now. Since I bought the car over a year ago, actually.
How am I supposed to wash the back side of the engine?
Old 05-10-2009, 07:06 PM   #5 (permalink)
cykaaro's Avatar
I usually spray the engine with an engine degreaser and let it soak in. Then spray with a power washer and get as much as the engine as I can. With the V6 there's a bit of room between it and the firewall that I can reach in and spray the back
Old 05-10-2009, 07:48 PM   #6 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
I'll usually come in from the driver's side (easier with the intake hose off) to spray from the top, and put the car up on jackstands to hit the back of the engine from the bottom. Let the degreaser soak for a bit, then rinse with a hose (I'm not a big fan of powerwashing an engine -- too many electrical connectors that are watertight, but not high-pressure watertight).
Old 05-10-2009, 08:25 PM   #7 (permalink)
If your worried about a pressure washer couldn't you simply substitute it for a 3 gallon Round Up sprayer or garden hose? BTW I used the sprayer a while back due to college dorm not having an exterior faucet (and it worked just as well as a hose). Yes it might not remove as much of the debris, but it should help.
Old 05-10-2009, 09:55 PM   #8 (permalink)
Junkyard Junkie
Yeah, I've never really felt comfortable power washing any part of my car.
What kind of degreaser should I use? A foaming kind most likely?
I've tried some clear spray on crap, looks like clear spray paint.
Didn't work worth a damn.
Old 05-10-2009, 11:49 PM   #9 (permalink)
hill8570's Avatar
Last engine I degreased, I used a couple of cans of Gunk Engine Brite Gel, then scrubbed as many areas as I could reach with an old pan scrubber (bristles on one end, and about a foot-long handle) before I rinsed the engine. Another method that works pretty well (takes longer, 'tho), is one can, scrub, rinse, then repeat hitting the areas you missed the first time. If you've got a really filthy engine, then it might be worth scraping with a plastic putty knife before trying the degreaser.
