Originally Posted by helloguysimnew
Is there an easy way to disassemble the solenoid or should the whole starter be replaced?
Solenoid's pretty easy to rebuild.
http://www.team-integra.net/forum/di...TopicID=123037 is a good write-up with pictures.
The FSM at
http://www.camrystuff.com/manuals/Gen4/Starting.pdf has a good write-up on starter removal -- it's pretty easy.
It's also somewhat possible that the starter relay (which is nowhere near the starter) has stuck in the "on" position. Very mildly possible that the ignition switch is has stuck in the "start" position. The relay can just be pulled out to see if that fixes the problem. See page 18 of
http://www.camrystuff.com/manuals/Gen4/99EWD.pdf for the location of the relay junction box (Junction Box #2 -- middle of driver's side engine bay), and the top of page 22 for the location of the starter relay in the junction box.
Before getting into the disassembly biz, you might want to give the solenoid housing (the big thing sticking out from the side of the main starter) a few middlin' hard wacks with a 2x4 or hammer -- might be enough to unjam the solenoid plunger, if that's the bad boy.
