Originally Posted by H.Rivera
from n tp d there s no kik.. i was actually at ah small incline and it took 5 seconds of going backwards for ot to stop moving.. and it was on d. and with a very small tap to the accelerator it inched foward slowly untill i press the brake. from n to r it only to 1 sec.
N-to-R sounds fine. N-to-D, ugh. Normally, you'd do the test with the main brake or the parking brake on, but I don't think it'd make much difference. Worth a try, I suppose.
Sounds to me like the forward clutch is feeling poorly -- not an easy thing to fix. Does your fluid smell burnt? If it's slipping as bad as I think it is, I'd expect there's some serious heat buildup there for a few seconds.
I'm interested in seeing what others here are thinking, 'tho -- I'm far from being the world's greatest tranny diagnostician.
If no one else comes up with anything better, you might want to try flushing out the RP with some standard Dexron III...I know some of these trannys get really pissy if the viscosity of the fluid is too low (such as when running Dex VI) - RP may just be "too good" for the tranny.
