97-01 Camry instrument cluster... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2009, 03:28 PM   #1 (permalink)
View axolotl81's Photo Gallery
How can I check the mileage on these without putting it in my camry? Any help will be appreciated. Thanks.
axolotl81 is offline   Reply With Quote
Old 05-15-2009, 11:07 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I really do not understand what your asking. You got one from the junkyard and want to see the mileage before you install it into your car?
5 Lug Corolla WHAT?
Old 05-16-2009, 09:35 AM   #3 (permalink)
I work at a junkyard and want to know how to test the mileage without the instrument cluster in the car. I should be able to use a 12 volt source, but don't know where to connect the tester wires onto the instrument cluster to get the mileage. I heard it was possible, but I'm not completely sure.
Old 05-16-2009, 10:22 AM   #4 (permalink)
Hmmmm.........I;m sure there is a way, but I'm not good with wiring.
I have the factory wiring diagram in PDF if you want me to email it. But you better be good at reading wiring diagrams, haha.
5 Lug Corolla WHAT?
Old 05-16-2009, 10:47 AM   #5 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
Just remove the old one and hook up the new one, it's very easy, two screws to remove the cover, then pull the cover, remove 4 screws around the odometer and that's it. I think there is a DIY...
El Tano is offline   Reply With Quote
Old 05-16-2009, 10:56 AM   #6 (permalink)
El Tano's Avatar
Here, this will help
http://www.toyotanation.com/forum/t88355.html
Good luck
Old 05-16-2009, 07:52 PM   #7 (permalink)
Thanks El Tano for the thread. That was a little helpful.
ASG14, if you wouldn't mind emailing me that wiring diagram I can see what pins exactly that I need to hook up to a 12v source. Email me at crabe1981@gmail.com
Thanks for the help everyone.
Old 05-16-2009, 10:48 PM   #8 (permalink)
Emailed. If for some reason you do not get it, send me a PM here on the forum.
~Adam
5 Lug Corolla WHAT?
Old 05-17-2009, 03:03 AM   #9 (permalink)
Got it. Thanks. You weren't kidding. This is gonna be a little confusing, but it should work. Thanks.
