Hello folks,
You guys may remember me from
this post.
Quick synopsis of related issue from the previous post mentioned above: 1993 Camry 4-cyl, Auto; taken in to local shop for nasty oil leak (1qt/2 weeks) - shop declared leak was from crank seal - shop did full timing belt service.
Anyway, surprise, surprise - lot's of problems since that shop "accomplished" the work. She's had to take it back due to the oil leak not being fixed. Once apparently the oil pan was
still leaking after they replaced the seal and once because the oil pump gasket was apparently leaking after they replaced that.
Now, for the
third time, apparently it is leaking from the rear main seal. This was an issue that the owner specifically said must be checked before doing ANY service originally; I recommended this to the owner because I was worried if they did the full timing belt service and the only other major leak source (rear main seal [since the valve cover gasket was recently done]) was indeed leaking, doing the full timing belt service was a waste and might as well junk the car. Well now we're here with ~$900 in work done on a 215k beater which is still leaking, apparently, from the rear main seal.
The shop claims the "oil leak moved" to the rear main seal and it wasn't leaking there when originally brought in. That "leaks can move because pressure increases when other leaks are fixed". This sounds like complete BS to me and they don't want to admit they screwed up and didn't properly check the rear main seal before doing all this work. I'm fairly certain that in order for a leak to cause a pressure differential that would be enough to be relevant, it'd have to be a significant
hole, leaking significantly more, pouring out of the damn thing.
Suggestions on next steps, how to deal with this shop? (Richmond, VA)
