Rear drum is rubbing against shield. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2009, 10:10 PM   #1 (permalink)
WheresMyCar's Avatar
View WheresMyCar's Photo Gallery
Where the arrows point it scraps with every rotation. It is bent because the other side has a proper even gap all around.
This is on a 97 camry I only want to make the scraping go away for now so I can drive it into storage.
Possible cause:
The wheels were hard(stuck) coming off. I kicked the wheel while it was lifted a few times. The car was sitting for 2 months. It could have already been bent but new rust may have now just caused it to make the scraping noise.
WheresMyCar is offline   Reply With Quote
Old 05-19-2009, 10:16 PM   #2 (permalink)
Togue superstar
t3chnique's Avatar
iTrader Score: 6 reviews
View t3chnique's Photo Gallery
try sanding that part that scrapes off.
Just suspension and cosmedics.
t3chnique is offline   Reply With Quote
Old 05-19-2009, 10:43 PM   #3 (permalink)
How will I rub it between the thin gap. How do I take the whole drum out to make it easier to sand?
Link? and tools I would need?
Old 05-19-2009, 11:24 PM   #4 (permalink)
Awsome TN User
View LeeRoc's Photo Gallery
ewww rust is teh suck
maybe this might help
its from the DIY section
DIY: GEN 3 Brake Shoe Replacement and Parking Brake Adjustment
:P
LeeRoc is offline   Reply With Quote
Old 05-20-2009, 09:59 AM   #5 (permalink)
Gameroom cash: $303255
Yes it's the rust. As rust forms it actuall swells the metal a bit. Sanding may not be enough. You may have to remove the drum and use a file on the inside lip of the drum to remove the rust. You might also have to file or at least bend back that section of the backing plate. That is a heavy amount of rust. Incidently, it is scrapping against what is called the backing plate.
Mike
Old 05-20-2009, 05:56 PM   #6 (permalink)
Thanks for the link. It would be easier to remove and sand it down. Thanks.
