IS A/C Compressor Working? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2009, 01:36 AM   #1 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
Where in the heck is the AC clutch/compressor on a I-4 1992 Camry? I looked and I cant find it. The AC isnt working at all. I dont know where to even hook up a meter to see what if anything is in the lines.
I dont know what in the heck is wrong with the system but I think looking at the compressor and seeing if the system is pressurized is a good 1st step.
Also How do I know the compressor and/or clutch is even working?
Deadly Sushi is offline   Reply With Quote
Old 05-20-2009, 02:32 AM   #2 (permalink)
View 500KCamry's Photo Gallery
It's directly under the alternator and run off the same belt.
You should be able to hear the clutch cycling. The electrical for it drops down from the alternator.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 05-20-2009, 05:39 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
You won't know that without a set of gauges, even if the compressor is spinning.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-20-2009, 10:49 AM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
The noise of the compressor working is kind of hard to miss (it's kind of a rattle-y sound).
You can get a go/no go check by looking at the sight glass on the seperator / dryer (immediately to the right of the radiator). When the ECU cycles the compressor on, the condensor fan (the "radiator" fan on the passenger side) will kick on, and engine rpms will bump up a bit. At this point, the sight glass should be clear. When the compressor kicks off, the fan kicks off, the engine rpms drop, and the sight glass should momentarily (half a second or so) look "bubbly".
This won't tell you much about how well the compressor is working, but it'll tell you that something is cycling pressure in the system.
Old 05-20-2009, 11:14 AM   #5 (permalink)
Thanks folks! OK, so shouldnt the compressor be cycling on/off much faster if there is no pressure in the system? Regarding that glass thing I havent seen it before but I'll take another look.
OHHHHH!!!!!!!! hey!!!!!!!! I almost forgot!!!!!! I bought a conversion kit from the old refrigerant to the new stuff!!! It has the connection thing, oil and new R-134 stuff. Is that easy to do? Im pretty sure it IS, but..... just wanna know.
Thanks again everyone!
Old 05-20-2009, 11:50 AM   #6 (permalink)
hill8570's Avatar
Typically the compressor won't cycle at all if the pressure is too low -- it's usually necessary to override the pressure switch when charging a completely purged system.
Um, it's easy to completely fsck up your rig with one of those conversion kits -- it's real easy to end up with black goo contaminating your entire system. Unlike years past, R-12 isn't super expensive these days -- I don't see the point of doing such a conversion.
Old 05-20-2009, 02:40 PM   #7 (permalink)
For someone with little to no A/C knowledge it's a minefield.
Old 05-23-2009, 06:05 PM   #8 (permalink)
CRAP!!!!!!!!!!!!
come ON! Why is it every time something breaks on me its a huge PITA!?!?
OK..... so where do i get R-12 then?
Old 05-24-2009, 10:52 AM   #9 (permalink)
You can't but it without a licence and you probably won't be able to find anyone willing to work on it any more. If you can buy some it will be very expensive.
