that's kind of high, but typical costs to replace a compressor will be quoted anywhere from $600-$1000. It's not only the compressor, but the reciever/dryer, a system flush and recharge. There is about 3hrs of labor in there too. Still though, A/C work always seems to be pricey. A reman'ed compressor is a crapshoot in my opinion. The quality of remans out there is very questionable. They may work, but possibly not optimal. They can perform subpar on very hot days.
If you want to do it yourself, I'd either buy a new compressor, or take a chance and pull a compressor at a junk yard and put it in. But you will need to flush the system yourself, and replace the dryer/receiver, then have it evacuated and recharged with freon and oil at an A/C shop. They will likely charge you $100-$150, so if you pull a used compressor, you can likely fix it for < $200. Otherwise with a new compressor and this DIY route, you are looking at $400-$500 min.
dave mc
